Home > Puma (Tdci) > DPF light and limp mode from flat battery |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6478 |
What codes have you got (rather than just trying to clear them)? 1988 90 Td5 NAS soft top
2015 D90 XS SW |
13th Jun 2019 9:45am |
Cake Member Since: 10 Jun 2015 Location: Essex Posts: 277 |
It is code P2463 which relates to a clogged DPF.
This isnt the case as car was running and fine until trying to start with a flat battery. Battery has been on the blink past few weeks as the car isnt used everyday and has tripped the engine light when attempted starts fail. |
13th Jun 2019 10:01am |
how old is your starting battery ? if it can not hold charge if land rover is not used every day
13th Jun 2019 10:46am |
It is 7 years old and can sit for a couple weeks. I have owned for 4 years now so not done bad really. Have another on now and CTek condition lights attached, the last never went off amber.
13th Jun 2019 10:53am |
neon1991 Member Since: 26 Mar 2018 Location: Colchester Posts: 74 |
ive got a 2007 2.4 and although I dont have a DPF I did have some strange issues when my battery went flat a few months ago. the main one was the a turbo over boost fault that put it into limp. tuned it off cleared the codes and re-started and been fine since. had it checked over prior to a re-map and all is fine apart from a weak battery.
13th Jun 2019 11:58am |
Yep i had that one too and it cleared no issue.
13th Jun 2019 1:49pm |
Can you read DPF presser on live data ? ford DPF presser differential sensor do fail common issue , DPF cleaning and re gen
13th Jun 2019 4:57pm |
This only happened with a battery change, the car never moved and was fine for the previous round trips to derby and dover with nothing abnormal in the car behaviour or any MIL lights what so ever.
I just want to know how the DPF light can be cleared so i can use it - if it returns then i will get it fully checked but to come on from failed starts without even running is extremely unlikely. |
13th Jun 2019 5:46pm |
dantastic Member Since: 04 May 2010 Location: London Posts: 367 |
You need to clear the diagnostic error. My nanocom can do it, don’t know about other brands but if you can get a buddy of yours around with a nanocom you should be able to get going again.
13th Jun 2019 7:19pm |
Christ a nanocom is expensive!
Seeing if Kwik fit can sort locally or be calling CSK to get scheduled in |
15th Jun 2019 8:08am |
sjc501 Member Since: 05 Feb 2018 Location: Glasgow Posts: 148 |
Hi Did you guys sort this issue ? Ive just had same issue .Battery was flat .I charged it and car starts ok now but now showing DPF Fault code . Just code it cleared by kiwis fit but it came on immediately .Strange
27th Sep 2019 11:34am |
CSK sorted it without any issues.
Perfect as always from Chris and his team. Fitted me in too as needed the car desperately. Just go there - Land Rover technicians have no idea and CSK on them day in and out, and for them was known and easy. |
27th Sep 2019 1:44pm |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 421 |
If your battery is 7 yrs old, you probably own a MY 2012. The first ones are famous for their loose DPF sensors (not fully tightened from factory)
I’d have that checked |
27th Sep 2019 3:40pm |
