Home > Puma (Tdci) > DPF light and limp mode from flat battery
Cake
Hi all, my car has had the DPF and engine lights come on with limp mode.
This was following a flat battery and several attempts of starting, battery charge and again failed atarting until replaced.
The car doesn’t pip around town and is used on long journey, the last was a 250 mile round trip from London to Derby and exhaust runs clean out the back so i know my DPF isnt full.
Does anyone know how to clear the codes?
StreetWise and ScanGauge2 readers fail to clear this (states failed).
Post #777313 13th Jun 2019 8:58am
Martin
Site Admin
What codes have you got (rather than just trying to clear them)?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #777318 13th Jun 2019 9:45am
Cake
It is code P2463 which relates to a clogged DPF.
This isnt the case as car was running and fine until trying to start with a flat battery. Battery has been on the blink past few weeks as the car isnt used everyday and has tripped the engine light when attempted starts fail.
Post #777323 13th Jun 2019 10:01am
dorsetsmith
how old is your starting battery ? if it can not hold charge if land rover is not used every day
Post #777327 13th Jun 2019 10:46am
Cake
It is 7 years old and can sit for a couple weeks. I have owned for 4 years now so not done bad really. Have another on now and CTek condition lights attached, the last never went off amber.
Post #777329 13th Jun 2019 10:53am
neon1991
United Kingdom 2014 Defender 110 Puma 2.4 USW Firenze Red
ive got a 2007 2.4 and although I dont have a DPF I did have some strange issues when my battery went flat a few months ago. the main one was the a turbo over boost fault that put it into limp. tuned it off cleared the codes and re-started and been fine since. had it checked over prior to a re-map and all is fine apart from a weak battery.
Post #777334 13th Jun 2019 11:58am
Cake
Yep i had that one too and it cleared no issue.
Post #777349 13th Jun 2019 1:49pm
dorsetsmith
Can you read DPF presser on live data ? ford DPF presser differential sensor do fail common issue , DPF cleaning and re gen
Post #777369 13th Jun 2019 4:57pm
Cake
This only happened with a battery change, the car never moved and was fine for the previous round trips to derby and dover with nothing abnormal in the car behaviour or any MIL lights what so ever.
I just want to know how the DPF light can be cleared so i can use it - if it returns then i will get it fully checked but to come on from failed starts without even running is extremely unlikely.
Post #777374 13th Jun 2019 5:46pm
dantastic
You need to clear the diagnostic error. My nanocom can do it, don’t know about other brands but if you can get a buddy of yours around with a nanocom you should be able to get going again.
Post #777378 13th Jun 2019 7:19pm
Cake
Christ a nanocom is expensive!
Seeing if Kwik fit can sort locally or be calling CSK to get scheduled in
Post #777566 15th Jun 2019 8:08am
sjc501
Hi Did you guys sort this issue ? Ive just had same issue .Battery was flat .I charged it and car starts ok now but now showing DPF Fault code . Just code it cleared by kiwis fit but it came on immediately .Strange
Post #795375 27th Sep 2019 11:34am
Cake
CSK sorted it without any issues.
Perfect as always from Chris and his team.
Fitted me in too as needed the car desperately.
Just go there - Land Rover technicians have no idea and CSK on them day in and out, and for them was known and easy.
Post #795400 27th Sep 2019 1:44pm
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
If your battery is 7 yrs old, you probably own a MY 2012. The first ones are famous for their loose DPF sensors (not fully tightened from factory)
I’d have that checked
Post #795425 27th Sep 2019 3:40pm
