Home > Puma (Tdci) > Puma 110 front springs compared to older models
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
I am looking to lift the front of the 110 a bit to compensate for the weight of the winch.
On my older 300Tdi I fitted the HD 110 front (which are the same as 90 rear) springs which makes quite a difference. However I know that the Puma front prop is susceptible to wobbles when lifted too much. Don't want aftermarket as none of them have yet figured out that springs need to be different lengths and they don't seem to last either.
What is the spring rate/length of a genuine Puma front spring compared to either a genuine Td5 or 300Tdi front spring? Wondering if they are stronger or weaker. The usual sources of info don't seem to cover the new stuff. ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #792948 14th Sep 2019 1:26am
MartinK
You need these:
http://bilashakaflowers.com/LandroverSprings.htm
And this for Puma
Road spring data
Road spring Part number Colour code
90 2 seat utility (2400 Kg)
Front - Driver's side REB500200 Red/green/white
Front - Passenger side REB500220 Red/green/orange
Rear - Driver's side NRC 9448 Blue/red
Rear - Passenger side NRC 9449 Yellow/white
90 2 seat utility (2550 Kg)
Rear - Driver's side RKB101230 Green/yellow/red
Rear - Passenger side RKB101240 Green/yellow/white
90 4 seat station wagon (2400 Kg)
Rear - Driver's side RKB500290 Red/green/green
Rear - Passenger side RKB500280 Red/green/red
90 4 seat station wagon (2550 Kg)
Rear - Driver's side RKB500270 White/green/pink
Rear - Passenger side RKB500310 White/green/purple
LHD 110 2 seat utility, 5 seat station wagon and 5 seat crew cab (3050 Kg)
Front - Driver's side NRC 8044 White/white
Front - Passenger side NRC 8045 Yellow/yellow
Rear - Both sides RKB101111 Purple/brown
RHD 110 2 seat utility, 5 seat station wagon and 5 seat crew cab (3050 Kg)
Front - Both sides NRC 8045 Yellow/yellow
LHD 110 7 seat station wagon (3050 Kg)
Rear - Both sides RKB500300 White/green/green
RHD 110 7 seat station wagon (3050 Kg)
Rear - Both sides RKB500300 White/green/gree Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #793538 17th Sep 2019 10:54am
BogMonster
Thanks. So you think the Puma models still have the same front springs? ---
Post #793941 19th Sep 2019 10:38am
