![]() | Home > Puma (Tdci) > Puma 110 front springs compared to older models |
BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 403 ![]() ![]() ![]() |
I am looking to lift the front of the 110 a bit to compensate for the weight of the winch.
On my older 300Tdi I fitted the HD 110 front (which are the same as 90 rear) springs which makes quite a difference. However I know that the Puma front prop is susceptible to wobbles when lifted too much. Don't want aftermarket as none of them have yet figured out that springs need to be different lengths and they don't seem to last either. What is the spring rate/length of a genuine Puma front spring compared to either a genuine Td5 or 300Tdi front spring? Wondering if they are stronger or weaker. The usual sources of info don't seem to cover the new stuff. --- 2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2680 ![]() ![]() ![]() |
You need these:
http://bilashakaflowers.com/LandroverSprings.htm And this for Puma Road spring data Road spring Part number Colour code 90 2 seat utility (2400 Kg) Front - Driver's side REB500200 Red/green/white Front - Passenger side REB500220 Red/green/orange Rear - Driver's side NRC 9448 Blue/red Rear - Passenger side NRC 9449 Yellow/white 90 2 seat utility (2550 Kg) Front - Driver's side REB500200 Red/green/white Front - Passenger side REB500220 Red/green/orange Rear - Driver's side RKB101230 Green/yellow/red Rear - Passenger side RKB101240 Green/yellow/white 90 4 seat station wagon (2400 Kg) Front - Driver's side REB500200 Red/green/white Front - Passenger side REB500220 Red/green/orange Rear - Driver's side RKB500290 Red/green/green Rear - Passenger side RKB500280 Red/green/red 90 4 seat station wagon (2550 Kg) Front - Driver's side REB500200 Red/green/white Front - Passenger side REB500220 Red/green/orange Rear - Driver's side RKB500270 White/green/pink Rear - Passenger side RKB500310 White/green/purple LHD 110 2 seat utility, 5 seat station wagon and 5 seat crew cab (3050 Kg) Front - Driver's side NRC 8044 White/white Front - Passenger side NRC 8045 Yellow/yellow Rear - Both sides RKB101111 Purple/brown RHD 110 2 seat utility, 5 seat station wagon and 5 seat crew cab (3050 Kg) Front - Both sides NRC 8045 Yellow/yellow Rear - Both sides RKB101111 Purple/brown LHD 110 7 seat station wagon (3050 Kg) Front - Driver's side NRC 8044 White/white Front - Passenger side NRC 8045 Yellow/yellow Rear - Both sides RKB500300 White/green/green RHD 110 7 seat station wagon (3050 Kg) Front - Both sides NRC 8045 Yellow/yellow Rear - Both sides RKB500300 White/green/gree Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Thanks. So you think the Puma models still have the same front springs? ---
