Home > Maintenance & Modifications > 2015 steering wheel spline
gibby1973
can anyone tell me what the spline size steering boss on a 2015 90 puma,cheers Rob
Post #793076 14th Sep 2019 11:33pm
CarMan
http://www.web-rover.co.uk/articles-steeringwheels.html Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
Post #793097 15th Sep 2019 8:54am
hank
Most likely 48 but the only sure fire way is to count. Pull the rubber cover off the centre, remove the nut and with the steering wheel in place count the splines with something pointy like a bradawl, pencil/pen, skewer or something. > 110 XS Double Cab
Post #793105 15th Sep 2019 9:33am
90 Dreamer
48 spline, have a similar truck and just done this
Post #793115 15th Sep 2019 10:02am
DSC-off
If ordering a new wheel or boss, be careful with 2015 MY on, they have DSC - stability control.
The steering wheel has a feature for a sensor on the column to measure the wheel angle.
Ensure the new wheel or boss is compatible with DSC if you have it. Thumbs Up
Post #793121 15th Sep 2019 12:29pm
gibby1973
Hi bud the truck is already fitted with a mono millennium steering wheel at Peterborough show they told me a direct fit..
Post #793164 15th Sep 2019 5:05pm
OsloBlue
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
Anyone know why LR decided to use two seperate spine nos?
Something technical? I'm on IG: https://www.instagram.com/osloblue42/
Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html
Post #793185 15th Sep 2019 6:39pm
90 Dreamer
I presumed (maybe wrongly) it was simply an age thing???
Post #793206 15th Sep 2019 8:04pm
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
Found some old stock in the back of the Unipart warehouse Laughing ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #793286 16th Sep 2019 10:14am
X4SKP
agree should be 48 (but count Thumbs Up )
 SKIP
Post #793287 16th Sep 2019 10:41am
Martin
Site Admin
Post 2008.5MY they are all 48 spline.
Post 2015MY aftermarket wheels need a different cancelling arrangement due to the steering wheel angle sensor fitted for the standard-fit DSC system.
Originally, 90/110/127 were 36 spline for the 4-spoke Range Rover classic type wheel.
With the introduction of the Defender, they went to 48 spline for the 2-spoke rubber wheel.
At 1998MY (last year of the 300 Tdi) station wagons went to a derivative of the 2-spoke RR classic type wheel with a blob in the middle, and used a 36 spline column to support this. Non station wagons continued with the 48 spline 2-spoke wheel as above.
In the middle of 2008MY production, the 2-spoke RR classic type wheel was finally switched to 48 spline so all Defenders then had 48 spline columns regardless of wheel style.
For 2015MY production, the introduction of DSC meant a change to the indicator cancelling system but 48 splines were retained.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #793327 16th Sep 2019 2:20pm
benniferj
On my TD5 I just popped off the raised centre bump cap thing and under neath on the wheel you could read off a model number (NRC_____) or something similar, can't remember.
That references a 48 spline wheel.
Saved removing it prematurely.
When you do remove it, loosen off the nut almost all the way, then wrestle with it so it's loose, then undo the last turn or 2 of the nut and remove. Saves you smashing yourself in the face with it Laughing
Post #793499 17th Sep 2019 9:04am
gibby1973
Oh yes I done it myself in a cosworth years ago.pulled wheel of and gave myself a bust nose.the Mrs panicked.i was more worried getting blod on my recaro Rolling with laughter Rolling with laughter
Post #793510 17th Sep 2019 9:27am
