![]() | Home > Maintenance & Modifications > LT230 Ratios |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2342 ![]() ![]() ![]() |
Yeah I hear you, but for me it's not so much about fuel savings as for drivability > 110 XS Double Cab
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1246 ![]() ![]() ![]() |
Gear ratios, particularly at motorway speeds, are largely irrelevant for fuel consumption. About a year ago I did work out all the maths and pretty much all of the 100+hp of a Defender engine is going into overcoming aerodynamic losses. The only significant way you're going to change mpg is by dropping your cruising speed. Ed
82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 924 ![]() ![]() ![]() |
Our 2.2 110 and Td5 90 both have the 1.2 ratio. The 110 has an Alive Stage 1 map, 235/85/r16 tyres, an AluCab conversion, AluCab 270 awning, 2x 55L auxiliary tanks, and a full length roof rack. When fully loaded it still drives nicely with the 1.2 ratio. It spends a lot of its life in the Alps and the hills aren’t a problem. The Td5 has 285/75/r16 tyres and a Td5inside map. It’s a lot lighter than the 110 but the higher gearing of the 1.2 just makes it a bit quieter on the motorway and town driving is fine. I can still get 5th gear just before 30mph. Charlie
1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6198 ![]() ![]() ![]() |
O/T... I changed the timing belt on my 200Tdi years back... a while after the crank snapped on that. turns out I'd refitted the pump and the timing was 180 degrees out. It ran perfectly, maybe slightly more knock, but not much. I figure there was a LOT of stress on the crank due to it firing at the wrong time which caused it to break. |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2353 ![]() ![]() ![]() |
Ed has special talents Jamie
![]() Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
Special pulley
![]() 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
