Home > Maintenance & Modifications > LT230 Ratios
Page 2 of 2 <12
excossack
hank wrote:
excossack wrote:
https://www.ashcroft-transmissions.co.uk/calc/ratio_calc.html
Thanks I hadn't seen that.
1.2 ratio, 6th gear @ 80mph = 2593rpm
1.1 ratio, 6th gear @ 80mph = 2356rpm
-237rpm difference.
1.2 ratio, 1st gear @ 10mph = 2378rpm
1.1 ratio, 1st gear @ 10mph = 2160rpm
-218rpm difference.
Worth it?
Now workout the theoretical fuel saving based on the reduced RPM.... 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #792719 13th Sep 2019 9:42am
hank
Yeah I hear you, but for me it's not so much about fuel savings as for drivability > 110 XS Double Cab
Post #792720 13th Sep 2019 9:50am
sako243
Gear ratios, particularly at motorway speeds, are largely irrelevant for fuel consumption. About a year ago I did work out all the maths and pretty much all of the 100+hp of a Defender engine is going into overcoming aerodynamic losses. The only significant way you're going to change mpg is by dropping your cruising speed. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #792725 13th Sep 2019 10:09am
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
Our 2.2 110 and Td5 90 both have the 1.2 ratio. The 110 has an Alive Stage 1 map, 235/85/r16 tyres, an AluCab conversion, AluCab 270 awning, 2x 55L auxiliary tanks, and a full length roof rack. When fully loaded it still drives nicely with the 1.2 ratio. It spends a lot of its life in the Alps and the hills aren’t a problem. The Td5 has 285/75/r16 tyres and a Td5inside map. It’s a lot lighter than the 110 but the higher gearing of the 1.2 just makes it a bit quieter on the motorway and town driving is fine. I can still get 5th gear just before 30mph. Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #792739 13th Sep 2019 10:42am
sako243 wrote:
Since then I've snapped two crankshafts s...
O/T...
I changed the timing belt on my 200Tdi years back... a while after the crank snapped on that.
turns out I'd refitted the pump and the timing was 180 degrees out. It ran perfectly, maybe slightly more knock, but not much.
I figure there was a LOT of stress on the crank due to it firing at the wrong time which caused it to break.
Post #792746 13th Sep 2019 11:14am
Mo Murphy
Ed has special talents Jamie Laughing
50 Shades of Pennine Grey
Post #792763 13th Sep 2019 12:02pm
sako243
Special pulley Rolling Eyes Ed
Post #792788 13th Sep 2019 1:51pm
Page 2 of 2 <12
