Home > Maintenance & Modifications > Td5 air conditioning illumination?
Mike c
England 2004 Defender 90 Td5 CSW Belize Green
Hi, I believe the control panel is supposed to illuminate on the air conditioning, can anyone confirm this?
Edit
After more googling I found this useful link on another forum, it seems it is supposed to be illuminated, however it looks like the bulbs are soldered in
https://www.lrukforums.com/threads/defende...nt.246129/
Unfortunately no information on what bulbs were used as replacements...
Thanks
Mike
Post #787886 20th Aug 2019 2:50pm
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
OMG! I have never seen the A/C unit illuminated, thought it was always just dark.
This is good, and bad all at the same time. Now I have to figure out how to get buns and get the lights working. Big Cry it's a Landrover thing...
my renovation thread:
http://www.defender2.net/forum/topic40792.html
Post #788069 21st Aug 2019 6:00pm
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
Mine used to light up after a few taps. Doesn't do it anymore.
Post #788075 21st Aug 2019 6:31pm
Mike c
Sorry! I never realised they were illuminated either until I found a post about it by accident, damn internet! Laughing
It's a relatively easy job to do but just don't know what bulbs are required at present so slightly frustrating!
Think these may be ok but not sure?
https://www.rapidonline.com/barthelme-2110...en-57-6825
Post #788076 21st Aug 2019 6:32pm
dorsetsmith
yes
pin 4 on both switch wire Red - black or red - orange illumination 12v + My 1999- 2001 only, work with side light switch
ground wire pin 3 on both switch wire blue - black
my 2002 pin 4 on both switch wire white -green illumination 12v + work with ignition switch
Post #788084 21st Aug 2019 7:30pm
Oakseywick
United Kingdom 2000 Defender 90 Td5 XS CSW Java Black
Damm yet another job neither of my land rover ac control panel light up so that twice I will have to do this Laughing Andy
Defender 90
Defender 110 XS
Cupra 290
Post #788144 21st Aug 2019 11:01pm
Justtellme
Canada 2003 Defender 110 Td5 SW Oslo Blue
i think I posted some pics a few years ago. the bulbs are not easy to change as they are small capless bulbs that are soldered in place.
Patrick
here is the link...it wasnt me that posted pics though......
https://www.defender2.net/forum/topic35096.html
Post #788156 22nd Aug 2019 3:08am
Mike c
Some useful information here thanks Thumbs Up
So the bulbs are 12v / 0.5watt types so those in the link I put in should be ok according to the tech spec? https://www.rapidonline.com/barthelme-2110...en-57-6825
Post #788173 22nd Aug 2019 8:02am
kyvlle
United Kingdom 2004 Defender 110 Td5 XS CSW Epsom Green
Thanks for this info! I was wondering for awhile what lights up and what doesn't in mine! Another job on the list!
Thumbs Up
Post #788315 22nd Aug 2019 8:57pm
geobloke
Yup same here, lack of illumination on the AC switches. Mind you coming from a 1992 Defender before this 2003 I was completely oblivious for at least 18 months to the fact that the heater controls on the dash were meant to be illuminated Whistle Rolling Eyes
Post #788377 23rd Aug 2019 11:41am
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
Sigh. Another job for the list Whistle
As the lamps are soldered to the board then they're ideal candidates for an LED. Don't forget the series resistor... R=(Vs-Vf)/I where Vs = 12V, Vf = the forward voltage drop of the LED and I = the desired current for the LED.
Post #788425 23rd Aug 2019 10:35pm
Mike c
Hi all, as an update, I managed to source some 2.5cm Led strips in the blue and green colour, they are 12v rated so no issues with having to get resistors too.
I purchased these from eBay so will see how they go, just needed to cut the wires down to the required length and solder on, seems fine so far and nice and bright.
Post #792441 12th Sep 2019 11:48am
jfh
Can a small LED be used?
Post #792549 12th Sep 2019 5:42pm
Mike c
Most of the single led bulbs that I could find were lower voltage so you would need a resistor too, the strips seemed like an easy option, I assume they have a resistor built into the strip circuit.
Post #792566 12th Sep 2019 6:23pm
geobloke
Hi MikeC. Can you provide some details on the led strips and the fitting please?
This appears to be "the solution"... Thumbs Up Thumbs Up Thumbs Up
Post #792690 13th Sep 2019 8:49am
