![]() | Home > Puma (Tdci) > Door Hinges (front) corrosion |
B4Lamb Member Since: 21 Mar 2015 Location: Abergavenny, Wales Posts: 233 ![]() ![]() ![]() |
I'm looking to replace the front door hinge securing screws with Marine Grade Stainless as I'm having some respraying done to the panels that are in need of repair and would like these hinges painted at the same time. I replaced the screws to the bonnet hinges and all those on the rear door and fittings on the rear 4 years ago and these are all bright and shiny with no dissimilar metal corrosion around these fixings to date.
I need to find out the size and length of the front door hinge screws (door and pillar side). They look about M8 size but I cannot easily remove them to check size and length as I don't have a suitable impact driver. The spray shop will have the means to remove and replace I'm sure but Id like to supply them a set of stainless fixings in readiness. Can Anyone Help?? "You are never to old to learn something new" |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18009 ![]() ![]() ![]() |
They are M8.
Thanks Blackwolf.
Any idea of the lengths? "You are never to old to learn something new" |
ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817 ![]() ![]() ![]() |
Here you have the size for all the door bolts. Part nbrs are for genuine.
![]() Click image to enlarge To certainly long term avoid any bi-metal corrosion make sure your body shop use plenty of a good quality and non hardening anti corrosion paste. My recommendation is either of the two below, with the second one having the advantage of being totally metal free. ![]() Click image to enlarge ![]() Click image to enlarge Last suggestion, I would recommend to again take all the already installed SS screws out again and dip them generously in this Weicon paste before reinstalling. If you do one bolt in/out at the time, you won’t disturb any door alignment. Easy do it yourself job. ![]() Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Thank you Eric. That's excellent info and top recommendations.
I've not used the weicon paste before so I'll look to get some quickly even if it's a week or so later after fitting the screws. I'd agree that a totally non metallic paste would be the best choice to minimise galvanic corrosion issues. "You are never to old to learn something new" |
I have a Defender 90 TDCI and therefore only 3 door. For simplicity the Front Doors require M8x1.25 x 55 long screws (8 off total) for the Door side of the hinges and these also need M8 Nyloc Nuts and plain washers inside the door. The Post side of the hinges need M8x1.25 x40 long screws (8 off total). It seems the rear cab doors on a 5 door model need the longer 85 and 95 mm long screws on the post side but I'm unable to confirm this.
The kits you can buy all seem to supply A2 grade stainless screws but I used A4 Marine grade with the same tensile rating. If you spend a lot of time near the coast the A4 (316 grade stainless) are much more resistant to corrosion. "You are never to old to learn something new" |
