Home > Maintenance & Modifications > Hex head drive flange bolts
CarMan
I've searched, as I know the info is here but I can't find Rolling Eyes Big Cry
Want to replace the bolts when I have my new HD flanges fitted, but I can't find the full spec.
Seems to me they need to be 10.9 M10 45mm threaded just half way.
Anything else I need to know Question
Had hoped to find on eBay, but not been successful so far, any help appreciated Bow down Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
2016 2.2 XS 90 hard-top
Post #792152 11th Sep 2019 5:00pm
Use hex socket head capscrews (what people incorrectly and annoyingly call "Allen bolts"), which are the right grade by default and widely available.
Post #792170 11th Sep 2019 5:52pm
I used as Blackwolf recommended, they did the job perfectly.
IIRC 10.9 or 12.9 are sufficient tensile strength but no lower.
I have just checked the sizes you quoted against my old ones I took out I had them to hand luckily enough.
The sizes you mentioned are indeed correct.
M10 x 45mm Long. Diesel$ Live$ Matter. β›½οΈπŸ›’οΈπŸ‘¨β€πŸ”§πŸ§°βš™οΈ RED, WHITE & BOOST! πŸ‡¬πŸ‡§
Post #792174 11th Sep 2019 6:12pm
Oh and don’t use SS bolts. But in my case I did not use Loctite at all on the threads and instead used stainless spring washers.
Then torque to correct torque. Diesel$ Live$ Matter. β›½οΈπŸ›’οΈπŸ‘¨β€πŸ”§πŸ§°βš™οΈ RED, WHITE & BOOST! πŸ‡¬πŸ‡§
Post #792176 11th Sep 2019 6:14pm
v8steve
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Rimini Red
just for the record.
10.9 grade standard . its bolts you want not setscrews (fully threaded)
socket cap screws (allan bolts) are 12.9 grade as standard
hope this helps 110 xs s/wagon
s3 swb soft top
Post #792177 11th Sep 2019 6:16pm
Re: Hex head drive flange bolts
CarMan wrote:
...they need to be 10.9 M10 45mm threaded just half way.
As a matter of passing engineering interest, this is the difference between a bolt and a setscrew - a bolt has a blind (unthreaded) portion, a setscrew is threaded thoughout its whole length.
Just thought you'd like to know.
Post #792178 11th Sep 2019 6:17pm
CarMan
Thanks very much guys, fascinating - but is there any chance of a link because I still can't find Rolling Eyes
If not, then no worries I'll make a trip to my local stockist called, believe it or not, Balls Grinding Snigger
Post #792181 11th Sep 2019 6:28pm
Devon-Rover
https://www.ebay.co.uk/itm/M10-10mm-HIGH-T...vmQbn7SsLQ
Thumbs Up Thumbs Up Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #792182 11th Sep 2019 6:30pm
CarMan
Bow down why couldn't I do that Rolling Eyes
Thanks so much , now I will have a good evening Thumbs Up Rob
Post #792185 11th Sep 2019 6:33pm
That’s the same supplier I used. Thumbs Up Diesel$ Live$ Matter. β›½οΈπŸ›’οΈπŸ‘¨β€πŸ”§πŸ§°βš™οΈ RED, WHITE & BOOST! πŸ‡¬πŸ‡§
Post #792187 11th Sep 2019 6:36pm
When I did mine, I used galvanised socket head capscrews and matching spring washers, torqued to 65Nm:
I have the fronts to do shortly, when I've finished painting a set of HD drive flanges and my new wheels and tyres are ready:
 Darren
Post #792244 11th Sep 2019 9:22pm
williamthedog
^^ ooh what a lovely half shaft you've got there Very Happy
Post #792316 12th Sep 2019 6:36am
CarMan
Didn't think about washers Rolling Eyes
Post #792317 12th Sep 2019 6:39am
CarMan
Mine have gone rusty (of course) even though painted so any chance of a link to the galvanised version please Thumbs Up Rob
Post #813929 6th Feb 2020 6:09pm
Used them myself, but can't remember what for ~ not a name you can easily forget.
Post #813937 6th Feb 2020 6:52pm
