Home > Puma (Tdci) > 2.2Tdci MY2015 hesitation
Gladys
Wales 2015 Defender 110 Puma 2.2 XS CSW Indus Silver
I have noticed the occasional hiccup at about 1600-1700RPM when driving in town, with the engine fully warmed up to temperature. It feels like an instantaneous loss of power, and I haven't noticed it at any other speed. There is no warning light present.
Having read the existing threads, I have checked for any loose or frayed wires on the engine loom, but nothing is apparent.
The vehicle has done 58,000 miles and has the DPF. Any thoughts relating to this particular set-up?
Post #787669 19th Aug 2019 4:23pm
andydef90
United Kingdom 2014 Defender 90 Puma 2.2 HT Corris Grey
if its driving while accelerating hard give the maf sensor a clean . brake cleaner will do it and a old toothbrush mine did the same thing a number of times without any warning light
Post #787673 19th Aug 2019 4:40pm
Vitesse
HI.. I have had the same intermiitent power loss issue recently 59k, 2015 Model year. I also had the MIL light come up and error code P0404. No idea if related but reset the code and so far light has not come back. No idea whats going to happen next but thought it might be of some help. Smile 2015 90 XS Santorini Black
Post #787679 19th Aug 2019 4:47pm
X4CAC
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
P0404 is the EGR valve...
I had the exact same issue with hiccups, new EGR valve fitted today and driving is now back to normal
Post #787700 19th Aug 2019 5:51pm
Vitesse
MIL Light on again today... p0404 code... Reset anf left it alone again until it comes back.
Agree....EGR next on the list to do! but it can wait! Thumbs Up 2015 90 XS Santorini Black
Post #787948 20th Aug 2019 8:54pm
Mike_E
United Kingdom 2015 Defender 90 Puma 2.2 HT Aintree Green
yep me too - 2015 with 48k on the clock,. maybe once a fortnight I get the hiccup. other than that it has been fine apart from once the missus was driving and it lost all power and she had to pull over. Restarted it, fine. No lights and no error codes. weird.
Post #787956 20th Aug 2019 9:18pm
Gladys
I haven't had any lights yet, but the fault seems to be happening a bit more often. I'll clean the MAF sensor as suggested first, but if that doesn't work I'll have to see if I can find the EGR valve.
Post #787979 20th Aug 2019 11:19pm
Gladys
The MAF sensor looked pretty clean, but I gave it a go with brake cleaner as suggested anyway.
As far as the EGR valve is concerned, has anybody stripped and cleaned one of these rather than fitting a new one? I am guessing that they fill up with Marmite, but may respond to a good clean out? As I haven't had any error lights yet, I wonder if mine may just be a bit sticky.
Post #788713 26th Aug 2019 5:54pm
Big Harold
Australia 2015 Defender 130 Puma 2.2 HCPU Alpine White
NOOO Don't use brake cleaner you need to use the proper MAF sensor cleaner.
Post #788749 26th Aug 2019 11:04pm
capnjapseye
United Kingdom 2016 Defender 90 Puma 2.2 HT Santorini Black
I had a similar issue with my 2016 2.2, done just over 32K. Had the EGR valve replaced & seems OK now. 2015 90 Hard Top
1998 90 300Tdi - chuffed to have another one
2013 Freelander 2 - for posher trips to the shop
1996 300 Tdi 90 Hard Top - sold 19th June 2020 - miss it, loved it
2016 90 Hard Top - demolished Nov 2019 by young driver 3.5 times over the drug limit
2010 90 Hard Top - now sold
Ex mil 90 - now sold
Post #791485 9th Sep 2019 6:20pm
Vitesse
Update. MIL on a few times now. p0404 code every time. Used my ultragauge to view Egr activity and definitely is getting stuck. So..... Egr replace it will be. Currently looking for best price on the part ....... 2015 90 XS Santorini Black
Post #791544 9th Sep 2019 9:04pm
Gladys
I got the impression that a Ford one is a lot less than a Land Rover one. Has anybody successfully used a Ford part on a 2.2 TDCi?
Post #791570 9th Sep 2019 10:18pm
Vitesse
I think it has been done and is part of my enquiry lines at the moment .... seems a fair bit on the web đź‘Ť. Pierburg appear to be an OEM supplier ?? Others may know more .... 2015 90 XS Santorini Black
Post #791583 9th Sep 2019 10:52pm
Gladys
Did you get anywhere with your enquiries? I still have no fault lights at the moment, but I have noticed the hesitation a litttle more regularly.
Post #792451 12th Sep 2019 12:21pm
Vitesse
Hi Gladys
I have purchased a good low mileage secondhand unit off eBay. Going to probably give it a clean and see how it goes
I have the MIL light and p0404 code but the car drives fine. I think the valve is jamned shut or slightly open. Bit of a gamble but worth a try. I do have extended Land Rover warranty but couldn’t be bothered with the likely grief of it all
Rolling Eyes 2015 90 XS Santorini Black
Post #792474 12th Sep 2019 1:34pm
