Home > Puma (Tdci) > 2.2Tdci MY2015 hesitation |
andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617 |
if its driving while accelerating hard give the maf sensor a clean . brake cleaner will do it and a old toothbrush mine did the same thing a number of times without any warning light
19th Aug 2019 4:40pm |
Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 372 |
HI.. I have had the same intermiitent power loss issue recently 59k, 2015 Model year. I also had the MIL light come up and error code P0404. No idea if related but reset the code and so far light has not come back. No idea whats going to happen next but thought it might be of some help. 2015 90 XS Santorini Black
19th Aug 2019 4:47pm |
X4CAC Member Since: 30 Apr 2018 Location: Midlands Posts: 212 |
P0404 is the EGR valve...
I had the exact same issue with hiccups, new EGR valve fitted today and driving is now back to normal |
19th Aug 2019 5:51pm |
MIL Light on again today... p0404 code... Reset anf left it alone again until it comes back.
Agree....EGR next on the list to do! but it can wait! 2015 90 XS Santorini Black |
20th Aug 2019 8:54pm |
Mike_E Member Since: 13 Apr 2017 Location: Aberdeenshire Posts: 160 |
yep me too - 2015 with 48k on the clock,. maybe once a fortnight I get the hiccup. other than that it has been fine apart from once the missus was driving and it lost all power and she had to pull over. Restarted it, fine. No lights and no error codes. weird.
20th Aug 2019 9:18pm |
Gladys Member Since: 28 Nov 2015 Location: South Wales Posts: 36 |
I haven't had any lights yet, but the fault seems to be happening a bit more often. I'll clean the MAF sensor as suggested first, but if that doesn't work I'll have to see if I can find the EGR valve.
20th Aug 2019 11:19pm |
The MAF sensor looked pretty clean, but I gave it a go with brake cleaner as suggested anyway.
As far as the EGR valve is concerned, has anybody stripped and cleaned one of these rather than fitting a new one? I am guessing that they fill up with Marmite, but may respond to a good clean out? As I haven't had any error lights yet, I wonder if mine may just be a bit sticky. |
26th Aug 2019 5:54pm |
Big Harold Member Since: 09 Jul 2018 Location: nsw Posts: 71 |
NOOO Don't use brake cleaner you need to use the proper MAF sensor cleaner. |
26th Aug 2019 11:04pm |
capnjapseye Member Since: 21 Feb 2015 Location: Cornwall Posts: 223 |
I had a similar issue with my 2016 2.2, done just over 32K. Had the EGR valve replaced & seems OK now. 2015 90 Hard Top
1998 90 300Tdi - chuffed to have another one 2013 Freelander 2 - for posher trips to the shop 1996 300 Tdi 90 Hard Top - sold 19th June 2020 - miss it, loved it 2016 90 Hard Top - demolished Nov 2019 by young driver 3.5 times over the drug limit 2010 90 Hard Top - now sold Ex mil 90 - now sold |
9th Sep 2019 6:20pm |
Update. MIL on a few times now. p0404 code every time. Used my ultragauge to view Egr activity and definitely is getting stuck. So..... Egr replace it will be. Currently looking for best price on the part ....... 2015 90 XS Santorini Black
9th Sep 2019 9:04pm |
I got the impression that a Ford one is a lot less than a Land Rover one. Has anybody successfully used a Ford part on a 2.2 TDCi?
9th Sep 2019 10:18pm |
I think it has been done and is part of my enquiry lines at the moment .... seems a fair bit on the web đź‘Ť. Pierburg appear to be an OEM supplier ?? Others may know more .... 2015 90 XS Santorini Black
9th Sep 2019 10:52pm |
Did you get anywhere with your enquiries? I still have no fault lights at the moment, but I have noticed the hesitation a litttle more regularly.
12th Sep 2019 12:21pm |
Hi Gladys
I have purchased a good low mileage secondhand unit off eBay. Going to probably give it a clean and see how it goes I have the MIL light and p0404 code but the car drives fine. I think the valve is jamned shut or slightly open. Bit of a gamble but worth a try. I do have extended Land Rover warranty but couldn’t be bothered with the likely grief of it all 2015 90 XS Santorini Black |
12th Sep 2019 1:34pm |
