Home > Maintenance & Modifications > Headlight relays
athelstan
United Kingdom 2015 Defender 90 Puma 2.2 CSW Montalcino Red
Headlight relays
I am thinking of changing the headlights to either uprated bulbs or LEDs.
Having had problems with the light switch on a previous, much older,Defender due to the lack of a relay being fitted in the circuit I thought I would do a bit of research.
I now have a 2015 2.2 XS and after seeing a You Tube video and suggestions of adding a new loom with relays I found a mention that the 2012 - 2015 Defenders were eventually fitted with a relay.
My question is, if this is the case, does this mean I do not need an uprated loom if I decide to go with uprated bulbs or LEDs. 2015 90 XS Station Wagon Puma 2.2
2015 Morgan Plus 4
Post #789320 29th Aug 2019 11:21am
oneten110
If Land Rover have fitted relays in the headlamp circuits, it would be a bit superfluous to fit more. Especially for LEDs which should have a lower current draw It is not a Defender, it is a One_Ten
Post #789400 29th Aug 2019 11:20pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Looking at MY2012 diagrams, the three-stage light switch controls relay R117 which carries the dipped and main beams' current. So no big load on that switch. A MY2008 diagram doesn't have that relay and the switch carries all the load.
The current however also goes through the dim switch. But that one wasn't the problem, wasn't it?
Post #789484 30th Aug 2019 11:25am
Oh yes it was, I am afraid. it is in the hands of the Gods which switch melts first or most often. I had more dip/main switches fail than on/off switches before I rewired my headlights properly.
Post #789504 30th Aug 2019 1:15pm
macfrank
Big Cry So I guess to fit a second relay for the dim switch was on LR's to do list for MY2017 then... Wink
Post #789506 30th Aug 2019 1:27pm
I expect the new Defender has one. At least I hope so.
Perhaps the optional Heritage Pack will have a programmable switch failure simulator built into the lighting ECU. Laughing
I found that the improvement in light output achieved by wiring the headlights with decent-sized cable straight from the battery via relays, and fitting Crystals, was so great as to make any further upgrades unnecessary. The fact that full battery voltage is available at the bulb has also produced a noticeable improvement in bulb life (it is well established that bulbs fail prematurely when operated at lower voltages than they're designed for).
Post #789510 30th Aug 2019 1:57pm
macfrank
Rolling with laughter
I didn't know THAT. I thought it was the opposite.
Post #789511 30th Aug 2019 2:00pm
90 Dreamer
Hi @blackwolf does this apply to the later Puma 2.4 / 2,2 cars even??
Post #789526 30th Aug 2019 3:05pm
ericvv
No, it is correct. Read the below.
https://www.google.ch/amp/s/www.topbulb.co...cycle/amp/ You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #789530 30th Aug 2019 3:29pm
dorsetsmith
07 to 2012 head light relay kits RH and LH driver as fitted by LR see below
https://www.defender2.net/gallery/albums/u...0relay.pdf
Post #789532 30th Aug 2019 3:30pm
Yes, I think (as dorsetsmith says above) that it wan't until 2012 that LR did anything about it, and I am not sure how good their solution actually is.
Anything prior to that benefits hugely from a wiring upgrade.
Post #789552 30th Aug 2019 4:04pm
macfrank
I tried to untangle the relevant parts of the wiring diagrams (I was about to try a new software but was faster on paper Embarassed )
The part framed in red was added as of MY2012 and I think it corresponds to what was added in the bulletin.
I added wire cross sections in red. Note there still is a "thick" 2.5 going to the relay 117 - for "historical reasons" Smile
So where would you recommend to improve this?
Post #789586 30th Aug 2019 5:55pm
athelstan
Many thanks for your replies folks, extremely useful. To someone who regards anything electrical as a black art, I think I am beginning to understand what relays do and why they are needed.
It has been mentioned that LED lights consume less current than conventional bulbs and coupled with the fact that hopefully Land Rover have now added a lighting relay into the circuit I might forgo the loom and put on as much LED gubbins that I can.
I've ordered a pair of LED stop/tail lights and a pair of LED Side Lights together with a pair of LED bulbs for the numberplate.
I'm currently using "search" on the forum for headlight reviews. 2015 90 XS Station Wagon Puma 2.2
2015 Morgan Plus 4
Post #789658 30th Aug 2019 10:47pm
Balvaig
Don’t forget that Led’s are polarity sensitive and will only work if connected correctly i.e positive to positive and negative to negative. Normal bulbs work with positive and negative to either terminal
It is always worth checking the existing wiring for polarity before fitting your new units. LR haven’t always bothered to get it right!
You will probably need a new relay for you indicators too. A search on the forum should assist you find a good one.
Hope all goes well.
Post #789675 31st Aug 2019 8:40am
athelstan
Thanks for pointing that out Balvaig, that will explain why when changing my wing light bulbs to LED on my other car, two out of the four bulbs didn't work and were binned forthwith. I'm only glad I didn't give the retailer a rollicking for selling shoddy goods. 2015 90 XS Station Wagon Puma 2.2
2015 Morgan Plus 4
Post #789722 31st Aug 2019 1:57pm
