![]() | Home > Maintenance & Modifications > Headlight relays |
NZOliver Member Since: 14 May 2025 Location: Christchurch Posts: 1 ![]() ![]() ![]() |
Hi The biggest problem I see is that the current is still all going thru the dip switch. ![]() I'm doing mine (2001 Defender) now and am using the main switch and dip switch to switch 3 new relays to run the lights. One for the parklight (sidelight to you British folk ![]() The hardest part is getting a high current cable to the fuse box in the cabin!! ![]() Oliver |
