Home > Technical > how do i remove this tab- removing pedal box
domm786
Scotland 1994 Defender 90 300 Tdi CSW Keswick Green
hi all,
im trying to remove my brake pedal box - 300tdi
ive got the 4 lower bolts out but the 2 upper bolts are behind this tab that doesnt seem to do anything? ive removed 3 screws that i can see and managed to pry down the driver side of the tab to remove a 5th bolt but the inboard side of the tab seems to still be secured in place by something? its either remove the tab to get at the last bolt or cut a section of the tab out which id rather not do.
much appreciated.
Post #788536 25th Aug 2019 12:19pm
dorsetsmith
remove the tab by palling it down with all 4 screws removed
Post #788544 25th Aug 2019 1:34pm
sako243
Slacken off the trim screws as well because they can clamp it in place quite effectively but it is just a case of pulling it down. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #788554 25th Aug 2019 2:45pm
domm786
thanks for the help lads. will give it a shot 😁
Post #788570 25th Aug 2019 4:33pm
oneten110
The function of the tab is to hold the footwell trim in place.
Strictly speaking you don't need to remove the screws, slackening them should be sufficient It is not a Defender, it is a One_Ten
Post #789355 29th Aug 2019 5:30pm
