![]() | Home > Technical > how do i remove this tab- removing pedal box |
![]() remove the tab by palling it down with all 4 screws removed |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1247 ![]() ![]() ![]() |
Slacken off the trim screws as well because they can clamp it in place quite effectively but it is just a case of pulling it down. Ed
82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
domm786 Member Since: 14 May 2016 Location: Scotland Posts: 56 ![]() ![]() ![]() |
thanks for the help lads. will give it a shot 😁
oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741 ![]() ![]() |
The function of the tab is to hold the footwell trim in place.
Strictly speaking you don't need to remove the screws, slackening them should be sufficient It is not a Defender, it is a One_Ten |
