| MussEd Member Since: 20 Feb 2013 Location: East Lothian Posts: 378
Today I took a blow torch my hub nuts and replaced them with nice SS ones, then took my car to have the steel wheels powder coated. My plan was to paint the hubs before this but my factory LR jack packed in on its first ever use last night so ran out of time today.
Click image to enlarge |
| Huttopia Member Since: 23 Feb 2016 Location: West Midlands Posts: 1978
I took the 110 to a bodyshop in Redditch to have the little 'bump in Bremen' sorted out, then drove the 90 to St Albans - I was just about to set off and a delivery driver turned up with the new air filter valve / bung so I fitted that. The old one was perished - and absolutely disgusting - a thick coating of oil / grime on it. I checked the air filter I fitted a week or so back and its fine so I assume the grime on the valve was from historical leakage!
The engine has started dripping a little bit of oil again, so more investigations needed. The gift that keeps on giving. |
| williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441
Stainless Steel isn't really suitable for holding the drive flanges on. They've got to be high tensile, 10.8 I think. |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18058
Are they stainless or BZP?
As far as I can see from zooming in, they seem to be head-stamped 10-9 in which case they are ideal. (The normal grade for a hex socket head capscrew is 10.9, which is the correct spec for the drive flange bolts). |
They are A4-80 which I thought suitable for this task? Please tell me this doesn't mean I need to get the blow torch out again for the copious amount of threadlocker I used yesterday! |
| v8steve Member Since: 18 Apr 2011 Location: dumfries scotland Posts: 195
standard cap screw are 12.9 grade. standard flange bolts 10.9.
cap screws in pic look like a4 70 or 80so not as strong and easier sheared just saying s3 swb soft top |
| GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387
I’d say that’s a recipe for a bad day. QRZ M8VPF
| RILEY Member Since: 01 Feb 2013 Location: United Kingdom Posts: 35
go easy on the clutch
| excossack Member Since: 22 Feb 2012 Location: North West Posts: 6045
Yesterday extended the control panel wires using thinwall 7 core trailer wiring.
Today i got the fuel line ran from the engine bay to the heater and attached the inlet pipe and exhaust. Air intake i think i am happy with, not 100% sure yet on the exhaust routing. Click image to enlarge 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
In that case I'd replace them as soon as possible with grade 10.9 or higher HT bolts. There are two major problems with A4-80 in this application; firstly they lack the tensile strength and ductility of the originals, meaning they are far more likely to shear, and secondly unless you used an anti-seize paste such as Weicon they are likely to cold weld themselves into the hub. Neither eventuality is good. Worst case may be that you already cannot remove them, I'm afraid. I have before now had an A4 screw weld itself into a nut before it was even tight. Horrible things, stainless fasteners! Personally I avoid them like the plague unless essential, and then use copious amounts of Weicon. |
| 90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2309
Click image to enlarge Out and about doing some messages and just because............ |
Went up The Peaks.
The early One Ten was utterly ‘my bag’. Surprisingly HOT, but very little traffic, on 4 & 2 wheels, as well as 2 feet and 4 hooves! The L200 was driven by a girl who’d NEVER been off-road before..... she is now a ‘vet” at it. Click image to enlarge Click image to enlarge Click image to enlarge QRZ M8VPF |
| Slideywindows Member Since: 09 Sep 2016 Location: North Essex Posts: 1311
That's a nice straight-looking early One Ten slidey-window hard top.
Not so many Y platers still around, can you tell us any more about it Greeni? I guess from the vent in the wing that it's been Tdi'd, has the owner kept the original engine? |
Yeah it has a 200 in it. On a galvo too!
Not sure about the og engine. I LOVED it, but what was most impressive, it’s the first vehicle he”s ever bought. I hope he never sells it. He was 3 up across the front seats, with missus and teen (i think) daughter! Not all heroes wear capes. QRZ M8VPF |
| All times are GMT |
