Home > Off Topic > Winch on your trailer? |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16979 |
https://bhwgroup.com/winches-and-hoists/reel-smart/
No problems with fleet angles with this ^^ ! I just use the Defender winch when needed. |
19th Aug 2019 10:25pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1572 |
Wonder how many £££££’s that is though
19th Aug 2019 10:46pm |
^^^ Many, I have no doubt, but it is a simple idea which could be replicated non-commercially easily enough.
The genuine IW winch mounts now fir to the two cross rails under the headboard, and IIRC there are two manual winches available, as well as a generic electric winch mounting platform. I guess the first thing you'd need to decide is the purpose of the winch, since this will determine the line pull and drum capacity you need. If you are only needing it to roll dead vehicles on their wheels onto the trailer then you won't need a big winch, and consequently the battery and charging system can be smaller and the nose-weight will be easier to control. Virtually all the trailer winch installations I have seen rely upon a plug-in connection to the towing vehicle with Anderson connectors, which I guess avoids the need to carry the weight of the battery on the trailer and avoids the need for a charging system. If you tend to tow the trailer a fair distance between winching operations, then a charging feed from a caravan-type connection (12S or 13-pin) could charge the battery, augmented by a solar panel. A compact winch, battery, solar charge system, with perhaps a vehicle charging feed too would be a neat solution. I look forward to seeing how this develops and hope that you show us pictures of whatever you decide to do. I'd be interested in any feedback on wireless remotes too, since there seems to be a huge difference between the cheap and cheerful and the "professional" ones. That's a nice trailer, by the way, even if the towing vehicle looks a bit "sus"! |
20th Aug 2019 8:59am |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1732 |
I made a removable tray for my IW flatbed, fitted through the central riveted panel the one way with pins and clips and the mount had a 40mm tube the other so it could be mounted on the rear of my 100" removable towbar - powered through an Anderson socket either directly when mounted on the 100" or extension leads when on the trailer - these also doubled as jump leads with another Anderson and a pair of heavy clips.
Sounds complicated but it was simple, and the Anderson lead was also used to charge the battery on the IW electric tipper. IIRC I used a Superwinch EP9000, also enabled it to be securely stowed away when not needed away from the trailer. HTH Keith |
20th Aug 2019 8:22pm |
Thanks Keith,
Have you got any pictures of your mount Keith? I’d also thought about making it some wonderful demountable winch, that slides along and joins in some how with where the head board post go and tie it in the middle where the genuine mount goes- then I catch myself on and think I’ve enough work in my life already I picked up a used Ramsey REP9000x it’s 24v, but cost me next to nothing. It’s a 16ft flat bed with 8ft ramps so shouldn’t be too hard to pull. |
20th Aug 2019 11:37pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7741 |
I had a winch on the ifor winch mount sitting forward and proud of the headboard, so sat over the a frame. Ran a 6000lb winch with Anderson off the vehicle. If you connect off Anderson sockets to the battery it's always got charge. Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
21st Aug 2019 7:12am |
As James says it was over the A frame, I had two HD pins welded to a winch mount that went through holes in the headboard frame with Ifor side board pins holding it, then the top of the winch frame just butted up to the rest of the headboard frame, then I had a threaded shackle (like for holding shipping containers etc) down onto an eye on the hitch.
I'll try and find a photo, I also had lashing points at the side of the bed so could use a snatch block on a strap to line up tow points etc. Good luck! |
21st Aug 2019 2:54pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19694 |
Could you not use one of those drill powered winches if you have or could create two suitable winch points on the trailer?
It would depend on weight I know and couldn't be too HD, but would save you a lot of work. Just an idea anyway. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
21st Aug 2019 11:27pm |
Don’t think I’d fancy pulling a D3 or Defender onto it with one of those think they’re only rated to 1.2 T?
22nd Aug 2019 12:11am |
Hard surface, 10% of load, plus 10% gradient. Approx 600kg load. 1.2t winch no problems maybe 20% for ramp? Cheers
22nd Aug 2019 11:39am |
