![]() | Home > In Car Electronics > Dim dip retro fit! |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20979 ![]() ![]() |
There is an econoseal plug under the drivers side (RHD) wing for it. Simply unplug it. This should then mean your headlights are off on sidelight. On dipped or main only. My headlight DRL is only on with sidelight because I bought LED’s with sidelight function piggybacked via the sidelights above. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
llessur Member Since: 15 Nov 2011 Location: Hereford Posts: 151 ![]() ![]() |
I will go hunting for it again - thank you
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17950 ![]() ![]() ![]() |
It's tucked up under the top surface of the o/s wing, not far from the aerial.
Thank you
Found the connector and unplugged it. Everything is working without the Dim Dip. It really is the small things that can make one happy ! |
Good job. When I did mine I also bought some male and female Econoseal connectors. Sealed the rear entries and plugged them in also.
This just safely seals up the connections and keeps them clean. ![]() Blackwolf originally pointed me in the right direction of finding it, it's not that easy to find either. ![]() ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
