Home > In Car Electronics > Dim dip retro fit!
Page 2 of 2 <12
Mike c
England 2004 Defender 90 Td5 CSW Belize Green
I had this on my first Defender, a 300tdi, hard to see the point to be honest! At the time I would have preferred to just have the sidelights on, that's more of a classic look, as long as they have standard bulbs Thumbs Up
Post #786814 14th Aug 2019 4:58pm
There is an econoseal plug under the drivers side (RHD) wing for it. Simply unplug it. This should then mean your headlights are off on sidelight. On dipped or main only. My headlight DRL is only on with sidelight because I bought LED’s with sidelight function piggybacked via the sidelights above. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #786824 14th Aug 2019 5:48pm
llessur
I will go hunting for it again - thank you
Post #786825 14th Aug 2019 5:53pm
It's tucked up under the top surface of the o/s wing, not far from the aerial.
Post #786838 14th Aug 2019 6:55pm
llessur
Thank you
Found the connector and unplugged it. Everything is working without the Dim Dip.
It really is the small things that can make one happy !
Post #786840 14th Aug 2019 7:22pm
Good job. When I did mine I also bought some male and female Econoseal connectors. Sealed the rear entries and plugged them in also.
This just safely seals up the connections and keeps them clean. Wink
Blackwolf originally pointed me in the right direction of finding it, it's not that easy to find either. Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #786868 14th Aug 2019 9:40pm
Page 2 of 2 <12
