![]() | Home > Technical > Removable winch mount |
| fatboyron Member Since: 28 Jul 2018 Location: Aylesham Canterbury Kent Posts: 116
no but I'm thinking the same sort of myself and I come across I think it's winchmax UK do portable carrier go on front your back with a 2in connector I was looking at the shadow bumper for the front and the terra Firma back
| Horneteer Member Since: 10 Feb 2015 Location: Cornwall Posts: 60
Hi Guys, I've done just that, the winch fits in a T Max winch mount that plugs into a 2" receiver.
I got some box section and made the front receiver picking up the 2 bolts each side on the chassis rails where the steering guard mounts and also added 2 more bolts through the bottom of the bumper. You can just see the receiver socket below the number plate. The winch mount is secured into the receiver with a 4" long 3/4"dia tractor pin as I didn't like the 5/8" pin that came with the mount. Click image to enlarge The winch is wired with 50mm² flexible cables via a 350A Anderson connector under the bonnet, with 50mm² cables back to the battery through an isolator. The winch has a stall current of 400A so even the 350A connectors could fry!! While the bonnet is open to connect the winch, I jam a wedge into the throttle linkage to raise the idle, also the open bonnet allows the engine heat to escape and protect the windscreen from flying winch gear I have a height adjustable tow hitch, so I've modified a spare slider into a rear receiver so the winch can be mounted at the back. I can get some pics tomorrow of the rest of the set-up. winch mount - https://bearmach.com/quick-mounting-set-ba-2665 Anderson connectors - https://www.altecautomotive.co.uk/anderson...5937-p.asp |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8489
I used to run a demountable front or rear system on my 110. It's sat in the garage for a while now. All came new from frogs island. Cradle with male 2" , female dixon bate slider, and front female mount. If it's of use make an offer. Pm me if interested. Cheers
Here's some more photo's
Front Receiver Click image to enlarge Rear Receiver Click image to enlarge Click image to enlarge Winch in it's cradle Click image to enlarge Click image to enlarge Anderson connector in the engine bay. (Old photo taken before rebuild) Click image to enlarge |
The set-up worked quite well and I managed to extract the Ninety complete with empty trailer one wet soggy January.
As for the tyres.... they were fairly new Discoverer STT's, not much good when clogged with mud Click image to enlarge Click image to enlarge Click image to enlarge |
| All times are GMT |
