![]() | Home > Technical > Removable winch mount |
fatboyron Member Since: 28 Jul 2018 Location: Aylesham Canterbury Kent Posts: 116 ![]() ![]() |
no but I'm thinking the same sort of myself and I come across I think it's winchmax UK do portable carrier go on front your back with a 2in connector I was looking at the shadow bumper for the front and the terra Firma back
Horneteer Member Since: 10 Feb 2015 Location: Cornwall Posts: 60 ![]() ![]() ![]() |
Hi Guys, I've done just that, the winch fits in a T Max winch mount that plugs into a 2" receiver.
I got some box section and made the front receiver picking up the 2 bolts each side on the chassis rails where the steering guard mounts and also added 2 more bolts through the bottom of the bumper. You can just see the receiver socket below the number plate. The winch mount is secured into the receiver with a 4" long 3/4"dia tractor pin as I didn't like the 5/8" pin that came with the mount. ![]() Click image to enlarge The winch is wired with 50mm² flexible cables via a 350A Anderson connector under the bonnet, with 50mm² cables back to the battery through an isolator. The winch has a stall current of 400A so even the 350A connectors could fry!! While the bonnet is open to connect the winch, I jam a wedge into the throttle linkage to raise the idle, also the open bonnet allows the engine heat to escape and protect the windscreen from flying winch gear ![]() I have a height adjustable tow hitch, so I've modified a spare slider into a rear receiver so the winch can be mounted at the back. I can get some pics tomorrow of the rest of the set-up. winch mount - https://bearmach.com/quick-mounting-set-ba-2665 Anderson connectors - https://www.altecautomotive.co.uk/anderson...5937-p.asp |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8364 ![]() ![]() ![]() |
I used to run a demountable front or rear system on my 110. It's sat in the garage for a while now. All came new from frogs island. Cradle with male 2" , female dixon bate slider, and front female mount. If it's of use make an offer. Pm me if interested. Cheers
Here's some more photo's
Front Receiver ![]() Click image to enlarge Rear Receiver ![]() Click image to enlarge ![]() Click image to enlarge Winch in it's cradle ![]() Click image to enlarge ![]() Click image to enlarge Anderson connector in the engine bay. (Old photo taken before rebuild) ![]() Click image to enlarge |
The set-up worked quite well and I managed to extract the Ninety complete with empty trailer one wet soggy January.
As for the tyres.... they were fairly new Discoverer STT's, not much good when clogged with mud ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
