Home > In Car Electronics > Dim dip retro fit!
doublea
Scotland 2016 Defender 110 Puma 2.2 Adventure Phoenix Orange
Dim dip retro fit!
Right, I know most folk ask about disabling dim dip, but I kinda like the retro look of it.
How do I go about retro fitting this to my 2015 utility wagon?
I'm hoping it's a case of getting the "pink relay" and resistor and plugging them in. Current Steeds:
2015 110 UW in Grasmere Green
2003 BMW F650 the Hack
2000 Elise
1992 Ducati 888 (no longer in bits, yahoo)
1990 TDR 250 (in bits again)
1988 TDR 250 (no longer in bits) and for sale
Post #786037 10th Aug 2019 12:41am
grafty99
The pink relay controls the headlights anyway so should already be there. If the wiring is there then it should just be a case of getting a resistor and plugging it in Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #786039 10th Aug 2019 7:00am
90 Dreamer
what is it exactly??
Post #786046 10th Aug 2019 8:33am
It is a useless feature which is optimised to make your headlight bulbs fail quicker!
It was actually a half-witted scheme by the UK government which meant that if you turned on the sidelights with the ignition on, the dip beam headlights would come on at about half power. It was for a short time in the late 1980s a legal requirement, until Europe, in a rare moment of sense, ruled that it was illegal under EU law for the UK to make it a legal requirement. So it stopped being a legal requirement!
Some manufacturers, especially those like Land-Rover, who thought the 1970s hadn't ended, went on fitting it for years before stopping.
Benefits of DD: none.
Disbenefits: running a headlight bulb on a reduced voltage has been shown to make it fail much quicker than running it on design voltage.
It is probably illegal to retrofit dim dip to a vehicle unless a configuration of the vehicle with DD has been through the EWVTA process, and then only to a class N (not M) vehicle. You'd have to compare the wiring diagrams to see exactly what is needed, but the DD system is more complex than you expect and you will be cutting and splicing harnesses to retrofit.
Post #786057 10th Aug 2019 9:24am
Sulisuli
Everyday is a school day, thanks blackwolf Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #786065 10th Aug 2019 9:53am
doublea
Oh well, sounds like it's not feasible.
It's just that super bright newfangled led DRLs just don't complement the retro look of my defender.
Thanks for the replies though. Current Steeds:
2000 Elise
Post #786067 10th Aug 2019 10:47am
90 Dreamer
cheers for the info....... Thumbs Up
Post #786069 10th Aug 2019 11:03am
If you want something DRL-esque but retro looking, then you could just turn the sidelights on. Darren
Post #786074 10th Aug 2019 11:19am
^^^ This! Rolling with laughter
Good idea, it's what I do.
Post #786080 10th Aug 2019 11:28am
JWL
Another way is to do what I did, I have a pair of crystal headlamps with pilot lights in. I popped a couple of led 501's in place and wired them up to the sidelight loom which give a fair impression of the headlamps being on allbeit not as bright as dipped beam as soon as the sidelights are turned on Thumbs Up
Post #786354 11th Aug 2019 8:50pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
DD will not work with LED head lights .... "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #786416 12th Aug 2019 7:17am
L110CDL
+1 Thumbs Up Clayton.
Keeper.
Post #786674 13th Aug 2019 9:04pm
discomog
There is nothing to stop you fitting filament bulb drls if you want a more "classic" look. In fact my Disco Sport has filament bulb drl's fitted as do many other modern cars. It means you can run with much brighter lamps than if using sidelights and without the glitz of LED's.
Don't see the point of dim dip Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #786679 13th Aug 2019 9:16pm
I very much agree with BW's mentioning of the DD system being very complex.
I disabled mine a few years ago, it was a real head scratcher to sort out and now I can't every remember how I did it.
I certainly wouldn't re-use it, I did not see the point in it either.
Now I run Noldens with in-built sidelight function, which gives me front sidelights and a DRL of the headlights only on when sidelights are on.. (Piggyback connected from the sidelight feeds.)
Dipped, and main.
Without the above and without the dim dip which I couldn't have with LED anyway. I would have only sidelights.
And headlights dipped or main.
With sidelight on headlights would be off completely.
I'm very happy with this set up, and the extra light from the DRL headlights with sidelights on really gives better visibility in dark weather especially if your Defender is black or grey.
For these reasons, although from what I have read you have a different set up I would agree with the others not to re-instate it. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #786704 13th Aug 2019 10:37pm
llessur
I have the Dim Dip on a 2008 2.4 . I have fitted led headlights and the effect is that they are on with the sidelights and very bright. I guess its the ability of Leds to operate over a wide voltage range. I have the 10050 pink relay but when I went hunting for the resistor to disconnect it, I could not find it.
Can anyone give me an accurate idea where it is situated with possibly the wire colour please.
I would prefer to have full control over my lights as I drive with side lights on when the trailer is attached as the trailer side markers tend to make oncoming drivers a little more aware of the width. At present they seem fixated that my headlights are on and just want to flash me.
Post #786810 14th Aug 2019 4:48pm
