![]() | Home > Maintenance & Modifications > LED headlight installation question |
El Rey Member Since: 25 Aug 2015 Location: Gunbarrel Highway Posts: 60 ![]() ![]() |
I'm going to try these LED headlights:
https://www.stedi.com.au/stedi-7-inch-carb...ight.html# As far as I can see there is only the three-way connector going into the existing headlight, but there is an extra red wire on the back of the LED headlight (see picture attached). Anybody know what that might be for, and if it's redundant, what to do with it? I'm an electrical n00b, so even the most basic advice appreciated. Cheers in advance ![]() Click image to enlarge |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6670 ![]() ![]() ![]() |
The original 3-pin has no facility to connect a side light or DRL or yes I would imagine that 12V on that red wire illuminates the DRL.
Sweet, cheers for that. There goes my plan to install them myself - will look for an auto sparky.
Don't use the DRL
Hah! Yes that's an option I guess.
Don't fancy a loose wire hanging around in there for some reason. Maybe a touch of OCD. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20872 ![]() ![]() |
A 1pole superseal connector capped would be suitable.
You could also take a feed from the sidelights givin you a DRL with sidelights only, Then you have a sidelights DRL, Dipped and Main. Ideally you sidelight should be LED as well though and you can get a piggyback loom to plug straight in lie Brendan at 4x4 Overlander has. ![]() ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Gracias - I’ll look up his Defender to see what you mean.
FYI I am meeting up with an auto sparky on Monday morning to help put all the lights in.
Will discuss the suggested DRL solution with him on the day, and post an update once it's done. |
DRLs connected to the side lights - look good!
The smoked lights look good all round too. Cheers again for the advice on here. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
looking fantastic.
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4807 ![]() ![]() ![]() |
Looks great. 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
A short clip of the dynamic side indicators too:
I like those
![]() 2008 SVX 90 2000 XS TD5 90 |
