Home > Td5 > Another Td5 with belt chirp !
Page 2 of 5 <12345>
Alextd5
United Kingdom 2006 Defender 90 Td5 XS CSW Bonatti Grey
5 miles later and the squeak is back! However I’m now worried as it’s not only a squeak but a tapping/knocking noise?? I have removed the belt, obviously the ‘chirp’ goes away however the knock remains ?
How do I upload a video?
Alex
Post #782969 24th Jul 2019 9:35pm
Alextd5
I’ve done it !
What do you guys think, I’m not convinced it’s the damper? Noisy injector?
If I’m honest it’s always had a noise, but it’s become extremely noticeable in the last few days.
Alex
Post #782971 24th Jul 2019 9:44pm
Alextd5
Any ideas on the knocking noise, mainly when hot?
I have replaced the crankshaft pulley.. I will wait a while before confirming the squeak has been cured!
Post #784668 3rd Aug 2019 3:03pm
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
Dampners for the Td5 are available at Turner Engineering for £145.50
Mine has been squealing on shut-down for years. Replaced belts, tensioners still no luck. This is going to be my next step.
https://www.turnerengineering.co.uk/lhg100...2x20634759 it's a Landrover thing...
my renovation thread:
http://www.defender2.net/forum/topic40792.html
Post #788061 21st Aug 2019 5:31pm
Paul V.
Netherlands 2004 Defender 110 Td5 SW Auto Zambezi Silver
Re: I’ve done it !
Alextd5 wrote:
https://youtu.be/efj5Q7bCc9k
Alex
Hi, what was the solution of your knocking noise ?
Our Td5 has the same noise...
Thanks, Paul
Post #791086 7th Sep 2019 8:28pm
Paul V.
Sorry Alex, i have a video but i have to find out how to upload 😳
Photo’s no problem.
It all start with a dead injector.
Bought a refurbished one at Craddock
After the assembly and correct adjustment of the injectors and replacing the seals of the other injectors the engine was running very smooth.
But with coolant temperature at 75 degrees during a testdrive i heard a ticking noise at idle.
So i have the ticking/ratle only even the engine is warm.
Pulleys, crankshaft camper are new.
This morning a dieselspecialist had tested the craddock injector.
The injector is performing well.
-Engine does not smoke
-Cilinder roughnes on my Hawkeye is good. ( between -1 and + 2)
-No problem to start the car
-No diesel in oil
Does my problem sound like yours ?
Did you solve your problem ?
Post #792654 12th Sep 2019 11:14pm
Paul V.
Photo’s no problem.
-No diesel in
oil
Post #792655 12th Sep 2019 11:15pm
Paul V.
Post #792656 12th Sep 2019 11:20pm
Alextd5
Yes. Sounds very much the same. I replaced all 5 injectors but it’s still doing it.
Post #792710 13th Sep 2019 9:27am
Alextd5
Actually is it the same as yours ?? Difficult to tell
Post #792711 13th Sep 2019 9:30am
Alextd5
I will add that not all diesel specialists can test Td5 injectors, having said that a bench test doesn’t always confirm a faulty
Or noisy injector.
I was told this recently by a well established diesel specialist.
Post #792996 14th Sep 2019 11:52am
Paul V.
My dieselspecialist told me I had to wish that the other 4 injectors should be so good as the refurbished injector wich i bought from Craddock !
I let them test the new injector because of the engine noise and I was afraid that the needle in it was not closing correctly wich can destroy the piston.
Post #793017 14th Sep 2019 3:09pm
Paul V.
Yesterday I changed the engine oil from 5W40 to 10W40.
Both full syntetic offcourse.
I’ve also checked the famous oilpump bolt.
The old bolt was correct tightened, and I saw a small sign of threadlock on it Rolling Eyes
(Our Def is a 2004 car)
With the new oil there was no difference cold and warm in engine noise.
But I noticed something else !
With the car parked and engine running idle I heard the noise.
Engine coolant was 91 degrees C.
Then I slowly turned the steeringwheel....noise was almost complete gone !
After that I switched on the aircopump, noise completely gone !
Conclusion: when I asked for a bit of power to the engine the noise is gone.
Bearings of the aircopump seems oké.
With the belt of I noticed some freeplay on the steeringpump pulley.
My waterpump is new.
The pulley is correct mounted on the steeringpump axle.
So what to do next....
Alex, would you check this also ?
- to be continued - Thumbs Up
Post #793020 14th Sep 2019 3:29pm
Alextd5
I eliminated the pulleys by running without the belt on when hot.. for a brief minute. The noise mine produces didn’t change.
I have checked and tested nearly everything I can, without stripping the engine of course. Since I noticed the noise I haven’t used it. I only know of three including yours which makes this noise! I think the next step will be finding someone who uses a picoscope.. whether this will flap up anything?
Post #793022 14th Sep 2019 3:58pm
Alextd5
I will try another ECU, although I’m 99% sure it’s not going to solve the problem, it keeps niggling me.
How many miles/km’s has yours done ?
Mines done 83,000 although irrelevant, the other Td5 I know which makes a similar noise has done 110,000.
Remapped, any modifications ?
Engine work carried out recently ? (Apart from injector)
Post #793025 14th Sep 2019 4:20pm
Page 2 of 5 <12345>
