![]() | Home > In Car Electronics > Front Fog/Spotlight Switch Issue |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 918 ![]() ![]() ![]() |
Update: the switch is not faulty. Is it the relay then? Charlie
1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
The back lighting should have its own feed from an orange cable, I used a tap off from one of the original switches on the dash.
This orange cable should be connected to pin 2 Pin 3 or 4 should be connected to earth. Pin 5 connected to the blue with white trace cable which is the full beam power wire. And pin 1 should be connected to terminal 85 on your relay. The switch is an earth switching switch rather than a power one... 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
MYSTERY Member Since: 14 Jun 2019 Location: Torquay Posts: 10 ![]() ![]() |
switch connection
Tribord Member Since: 20 Apr 2013 Location: France Posts: 220 ![]() ![]() ![]() |
Just checking - is this last wiring diagram the best way to wire in spots (with direct connection between 30 and 86) when wiring spots without high beam trigger (just on-off switch)?
LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11325 ![]() ![]() |
Without a switch, pin 85 on the relay would need to be connected directly to earth for it to work. Darren
LRAnorak - sorry I didn't quite understand. I am using the switch, but not a high beam trigger.
I have it wired as per above diagram, and it works. Just wondering if the relay link is the best way of doing it. |
Ah, sorry - my mistake. I can see where you've altered the original diagram now.
Yes, that would work fine. The switch is used to earth the relay coil, which has a permanent live supply. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Horneteer Member Since: 10 Feb 2015 Location: Cornwall Posts: 60 ![]() ![]() ![]() |
If you wanted the bar to work only with head lights, then do away with the red link between pins 30 and 86 and connect a head light feed on to relay pin 86. |
I wanted to keep the spots separate from headlights, so used as per diagram above. Working well through the bearmach switches for spots and rear work light.
WITH HEAD LIGHTS
ForeignCartographer Member Since: 15 Jul 2021 Location: Scotland Posts: 13 ![]() ![]() ![]() |
Hi,
Don't laugh at me for this question but, how do I connect the ground/earth from the switch? Can I splice into a ground wire from another switch? Cheers Ben |
Yes you can although any convenient earth point will do. Darren
Thanks Darren
Hi again!
I was wondering: does the switch have to be grounded in order to complete the circuit and work, or is that only for the lights on the switch? Cheers Ben |
