Home > In Car Electronics > Front Fog/Spotlight Switch Issue
Page 2 of 2 <12
No, it's integral to its' operation. It switches the earth on and off for both the accessory it's controlling and the indicator light. Darren
Post #912783 17th Jul 2021 1:31pm
ForeignCartographer
United Kingdom 2013 Defender 90 Puma 2.2 SW Arles Blue
MYSTERY wrote:
switch connection
Thanks again Darren.
How am I supposed to connect pins 30 and 86 on the relay? I tried a piggyback spade connector but I don't think it's working... I think everything else is connected properly, so I reckon that's the weak link. Does the linking wire need to be able to handle 30 amps? What I'm powering draws up to 30A.
Ben
Post #912807 17th Jul 2021 5:14pm
No, the link wire is just for the relay coil, so takes very little current.
There are lots of ways to join the wires from solder to crimp connectors to choc blocks. If you think that's where the problem is then try buzzing it out with a multimeter to confirm the continuity. Darren
Post #912830 17th Jul 2021 8:27pm
ForeignCartographer
Okay will do! Thanks for your help
Ben
Post #912837 17th Jul 2021 9:31pm
ForeignCartographer
Got it working. Thanks again!
Post #913311 20th Jul 2021 11:29pm
Great. Why don't you share some pictures of what you've done? We like pictures Smile Darren
Post #913333 21st Jul 2021 7:09am
ForeignCartographer
I'm afraid there's nothing to show as it's a kill switch!
Post #913407 21st Jul 2021 12:41pm
Page 2 of 2 <12
