![]() | Home > Puma (Tdci) > Identifying a sensor on the lower part of the engine |
lube oil level
pux146 Member Since: 30 Apr 2018 Location: Wiltshire Posts: 121 ![]() ![]() |
Thanks, I can’t find the lead that goes to it! Should it be plugged in? 😱 2007 2.4 90 fettled & remapped.
Should it be plugged in? see below
www.defender2.net/forum/topic29440.html?hi...vel+sensor |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4292 ![]() ![]() ![]() |
I wonder if this was not used because the Defender is expected to be used at extreme angles off road and it would trigger false low level warnings? Just a thought, but it could explain why something potentially very useful in protecting your engine is not used. 2007 110 TDCi Station Wagon XS
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2347 ![]() ![]() ![]() |
from the linked thread above
"you may find its not connected or used as the puma engine leans back more in defender compared to when fitted in the transit giving a wrong reading" > 110 XS Double Cab |
Once again chaps thanks for the advice, stops me panicking that something’s fallen off 😂 2007 2.4 90 fettled & remapped.
JPE Member Since: 19 Nov 2018 Location: South West England Posts: 344 ![]() ![]() ![]() |
Interestingly I have a cable plugged in there, but mine's a 2.2.
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1124 ![]() ![]() ![]() |
According to the MY2012 workshop manual it‘s an oil level AND temperature sensor, of which only the temperature is used.
It’s connected to the ECM with black a 3 pin connector (C2257) ![]() Click image to enlarge |
Thanks Macfrank. 2007 2.4 90 fettled & remapped.
