Home > Puma (Tdci) > Identifying a sensor on the lower part of the engine
pux146
Hello, whilst looking for the starting problem the other day I came across this sensor with no plug in, I can’t even find a lead for it! Or is it supposed to be unused? Any ideas cheers.
 2007 2.4 90 fettled & remapped.
Post #783203 26th Jul 2019 10:07am
dorsetsmith
lube oil level
Post #783210 26th Jul 2019 10:35am
pux146
Thanks, I can’t find the lead that goes to it! Should it be plugged in? 😱 2007 2.4 90 fettled & remapped.
Post #783213 26th Jul 2019 10:49am
dorsetsmith
Post #783215 26th Jul 2019 11:27am
Bluest
I wonder if this was not used because the Defender is expected to be used at extreme angles off road and it would trigger false low level warnings? Just a thought, but it could explain why something potentially very useful in protecting your engine is not used. 2007 110 TDCi Station Wagon XS
Post #783221 26th Jul 2019 12:30pm
hank
from the linked thread above
"you may find its not connected or used as the puma engine leans back more in defender compared to when fitted in the transit giving a wrong reading" > 110 XS Double Cab
Post #783222 26th Jul 2019 12:38pm
pux146
Once again chaps thanks for the advice, stops me panicking that something’s fallen off 😂 2007 2.4 90 fettled & remapped.
Post #783245 26th Jul 2019 3:21pm
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
Interestingly I have a cable plugged in there, but mine's a 2.2.
Post #783247 26th Jul 2019 3:35pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
According to the MY2012 workshop manual it‘s an oil level AND temperature sensor, of which only the temperature is used.
It’s connected to the ECM with black a 3 pin connector (C2257)
Post #783358 27th Jul 2019 7:38am
pux146
Thanks Macfrank. 2007 2.4 90 fettled & remapped.
Post #783384 27th Jul 2019 10:47am
