Home > Technical > Lof clutches
jst
Lof clutches
Soft top clutch has a slight rattle, so what's the verdict on going for something like lof clutch over a std one. What are the differences, advantages? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #782988 24th Jul 2019 10:45pm
Bluest
It’s not so much the advantages of LOF (or Clutchfix for that matter) as avoiding the complete garbage that is the standard clutch. The springs on a standard one are too weak, they get squashed, rattle like hell then eventually fall out. Mine are in the rattling like hell phase at the minute. I’ll go with either LOF or Clutchfix before my next big trip, but I don’t really have a preference for one over the other. 2007 110 TDCi Station Wagon XS
Post #782989 24th Jul 2019 10:55pm
bankz5152
LOF. Luke is brilliant and goes above and beyond for his customers. His products are very good as well.
Post #782997 25th Jul 2019 6:03am
Zed
Yep, excellent products and service that is second to none.
Post #782999 25th Jul 2019 6:15am
geobloke
I have had a power-spec clutch from LOF for the better part of 18 months now, Probably covered somewhere near 14,000 miles. I bought it because the Valeo clutch I fitted 18 months earlier had begun to slip, especially on steep hills or slip roads when accelerating. I went through all the usual possible reasons for the slipping, including having a remapped ECU, oil contamination, coolant contamination... It got pretty alarming near the end so I was ready to try something uprated...!
As my flywheel was only 18 months old Luke advised that continuing to use it would be alright but to take it easy for 500 miles or so to let the fly and plate to bed in together and whilst doing so to "take it easy" on the go pedal. This was probably the most agonising but relaxing 800ish miles I have driven in ages.
Luke was right and the "mating process" was entirely successful Thumbs Up Thumbs Up
Since that point the clutch has performed brilliantly with not a trace of slipping and allowing all the horses (that have not fled the stable in 200+k miles) to get their hooves down. UP hill, down dale, loaded up to the gunnels, on and off road...
The only thing to mention is that the clutch pedal is now marginally heavier than with the original Valeo setup. It is not obtrusive and you quickly get used to it. The addition of the clutch spring helps with this though...
Apart from that the actual difference between the quality of workmanship between the Valeo and LOF units really cannot be compared, it'd be like comparing a cave matured cheddar with squeezey cheese from a can... Everything is made better but it does the same job. Plus I liked the massively uprated release bearing and clutch fork retaining clip.
All in all I am a very happy Defender owner and am equally happy to recommend the product and service from Luke at LOF.
Post #783015 25th Jul 2019 8:35am
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Big thumbs up for Luke at LOF. Just fitted one of his clutch kits and at the same time replaced the output shaft. Felt for an extra hundred quid it was worth future-proofing it. His kit included oil seal, release bearings etc. The new clutch is lighter and so far spot on. Also great customer service.
Post #783023 25th Jul 2019 9:33am
jst
Ok, thank you all. Get the bit on the springs.
So there are different spec lof clutches then? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #783165 25th Jul 2019 11:26pm
bankz5152
Road, power, extreme, race.
All provide different levels depending on use and power output.
Post #783175 26th Jul 2019 6:39am
jst
ok, best i do some more digging.
So who on here actually has one fitted and for how long please? anyone over 60k miles with one fitted? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #783318 26th Jul 2019 9:47pm
Another option, one favoured by respected forum member dgardel, is the 4x4 Transit clutch. Much better apparently that the LR version.
Post #783335 26th Jul 2019 10:23pm
Sulisuli
Have a chat with Roy5695 he has one fitted Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #783680 28th Jul 2019 9:11pm
Roy5695
I run a good stage 2 map from Alive on my Road Spec LOF clutch. It’s handled everything I’ve thrown at it so far.
Very spirited driving up and down the hilly A30, a ton of concrete or soil in the pick up. Feels nice on the clutch pedal and doesn’t rattle!
Luke’s a top guy as well and will gladly chat to you about what you want and need, he actually talked me out of buying the power spec one as he said the Road spec is incredibly strong. Saved me some money too! 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #783863 29th Jul 2019 7:41pm
geobloke
Probably close to 20-25k miles now JST with a strong IRB Developments map. All good.
The same cannot be said for the reconditioned transfer box fitted in January Whistle Rolling Eyes
Post #783958 30th Jul 2019 7:54am
Daisy90
United Kingdom 2001 Defender 90 Td5 SW Alveston Red
I have had a LOF clutch kit fitted a few months back now, it was the one up from std spec if I remember correctly,
As mentioned above I took it VERY easy on the throttle for 1500 miles ( they say 1000)
Also had a flywheel
Got to say it's fine to drive now without a sniff of clutch slip,
My 90 runs a big remap from IRB, big inter cooler and D2 gearing,
After fitting three different clutches in about 2 years I'm happy with the results
Works for me Thumbs Up
Post #784449 1st Aug 2019 9:15pm
NickMc
I must ring Luke and order one for the tdci and 200 tdi next week. Only heard good things too
Post #784471 2nd Aug 2019 12:01am
