Home > Off Topic > Anyone with a Howling Moon RTT
rallysteve
Not sure whether i have some bits missing from my Tourer RTT or if i am just being thick.
I cant work out where the bottom of each of the 6 tension rods for the windows fit into. The top hooked part obviously goes through the eyelets in the window flaps but there isnt anything suitable at the bottom for the rod to fit into. There are obvious access points through the skirt and annex to allow the rods to pass through but it is just the featureless aluminium extrusion which runs around the base of the tent behind.
Can anyone explain or share a picture of how they are retained?
84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale
Post #782413 21st Jul 2019 5:31pm
v8steve
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Rimini Red
should be holes in the aluminium approx behind holes in bottom skirt of tent.
holes angled at about 45 degrees.
hope this helps
steve 110 xs s/wagon
s3 swb soft top
Post #782414 21st Jul 2019 5:35pm
rallysteve
Thanks, i am starting to think it is not right...
Flap in the skirt:
Aluminium beneath the skirt:
Post #782416 21st Jul 2019 5:42pm
Whirly90
England 1993 Defender 90 300 Tdi HT Keswick Green
This shows the set up of the Stargazer which is basically the same tent, fast forward to 3.10 to se the exact location of the window rod holes
&t=203s
Post #782454 21st Jul 2019 8:23pm
rallysteve
Great thanks,
Definitely don't have those holes! The only features on that extrusion are the screws that hold it on.
Guess i will give Flatdog a call
Thanks
Post #782462 21st Jul 2019 8:51pm
Martin 01
Steve,
Your definitely missing the tube in the sides to take the metal support rods.
Post #782749 23rd Jul 2019 6:54pm
rallysteve
Thanks, a message to Flatdog has concluded the same. They are going to drill some suitable holes when I next go over to get the awning fitted.
Cheers,
Post #782837 24th Jul 2019 10:29am
rallysteve
To close this out. Flatdog finally drilled the holes around the aluminium strip and fitted the inserts for the window rods! The next use of the tent should be a little better now Laughing
Post #803073 21st Nov 2019 1:41pm
AJC
I have a similar issue with mine, except I've no dowels for the metal pole nor little letter boxes in the canvas.
Post #803086 21st Nov 2019 5:14pm
