Home > Off Topic > Anyone with a Howling Moon RTT |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2200 |
Not sure whether i have some bits missing from my Tourer RTT or if i am just being thick.
I cant work out where the bottom of each of the 6 tension rods for the windows fit into. The top hooked part obviously goes through the eyelets in the window flaps but there isnt anything suitable at the bottom for the rod to fit into. There are obvious access points through the skirt and annex to allow the rods to pass through but it is just the featureless aluminium extrusion which runs around the base of the tent behind. Can anyone explain or share a picture of how they are retained? Cheers Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
21st Jul 2019 5:31pm |
Thanks, i am starting to think it is not right...
Flap in the skirt: Click image to enlarge Aluminium beneath the skirt: Click image to enlarge Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
21st Jul 2019 5:42pm |
Whirly90 Member Since: 01 Sep 2016 Location: Ampshire Posts: 401 |
This shows the set up of the Stargazer which is basically the same tent, fast forward to 3.10 to se the exact location of the window rod holes
&t=203s |
21st Jul 2019 8:23pm |
Great thanks,
Definitely don't have those holes! The only features on that extrusion are the screws that hold it on. Guess i will give Flatdog a call Thanks Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
21st Jul 2019 8:51pm |
Martin 01 Member Since: 13 Feb 2012 Location: East Yorkshire Posts: 500 |
Steve,
Your definitely missing the tube in the sides to take the metal support rods. |
23rd Jul 2019 6:54pm |
Thanks, a message to Flatdog has concluded the same. They are going to drill some suitable holes when I next go over to get the awning fitted.
Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
24th Jul 2019 10:29am |
To close this out. Flatdog finally drilled the holes around the aluminium strip and fitted the inserts for the window rods! The next use of the tent should be a little better now
21st Nov 2019 1:41pm |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1333 |
I have a similar issue with mine, except I've no dowels for the metal pole nor little letter boxes in the canvas.
21st Nov 2019 5:14pm |
