![]() | Home > My Defender > Baltic blue 110usw |
Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 620 ![]() ![]() |
No stopping me now
Mirror arms and crossmember done too ![]() Click image to enlarge |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11062 ![]() ![]() |
Great bit of work going on there, is there any more left to do
Great news with the 6 week break, that will give you a chance to catch up on all the maintenance on the vehicle's, can't beat a good tinker time
About two years ago a new head was fitted under warranty for no real reason and therefore injectors must have been removed. Anyhow recently I had started to get a funny sound when cold. Almost a popping and a bit of a tick. Last night I removed the engine cover and nipped up the injector clamps to the correct torque. They went round about 1/2 a turn to 6nm then another 180 to finish. What a difference no popping and the tick has gone too.
Side steps removed. Off side was a bit rattly. This was the result when I took end caps off a drilled the rivets out of the step plates
![]() Click image to enlarge Absolutely crap |
I had a puncture a couple of weeks ago and checked the front drive members and they showed enough play to need replacing before ordering I thought I’d check the back. They need doing too. They were quite dry and dusty inside.
Replaced all four drive members along with new gaskets and bolts. Drives like a different truck. The clunk has gone and the movement on the handbrake is now minimal. Very happy spannerer. All coming off again in a week or so as when I was in there i put a mic on all four discs and they are below the limits. New discs, pads and pins on their way.
Sure is a lot of happy spannering going on
Oh yes.
Took some kids from work to see this in Liverpool today ![]() Click image to enlarge Then went to lrparts to pick up all the parts for my brakes. Don’t know what the kids found more impressive the QM2 or the rolling chassis in the lrparts showroom. |
Nice pic of the QE2
![]() The latter i would think ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
![]() Click image to enlarge Box of dinitrol from Rejel arrived today. So with new brakes all round. Side steps to paint and refit and a full rust proofing job it’s going to be a busy week. |
Busy week. Dinitrol applied, side steps welded filled painted and tops reinstalled with rivnuts. Three corners with new brakes. Last one this morning then mud flaps back on and finished. Just a good wash required. Il post some pics when completed.
Best laid plans and all that. One hub nut got jammed. Needed a new nut, stub axel, seals etc. Total cost about £20. But now I have new brakes all round and good for a good few thousand miles.
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4807 ![]() ![]() ![]() |
Looking forward to seeing the dinitrol pics, you have certainly been busy
![]() 2008 SVX 90 2000 XS TD5 90 |
