![]() | Home > Puma (Tdci) > 2016 Puma - problems with 1st and 2nd gears AFTER service |
| Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 737
Did they change the clutch fluid. If so I would suspect that you have air in the system and the clutch need bleeding.
| El Rey Member Since: 25 Aug 2015 Location: Gunbarrel Highway Posts: 60
Thanks for the reply. That hadn't occurred to me as a possibility - cheers
| andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617
is it too far to go back after all you have paid for a service and they have created the issue
@andydef90
It's only an hour's drive to the shop so not too bad. I contacted them as soon as I noticed the issue, and said I would monitor it and get back to them if it continued. So next week I'll be getting back in touch and asking them to sort it out. |
| Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 306
Maybe double check your gearbox drain & filler plugs are tight.
@ Marks Landy - Cheers for that. Another thing to check when getting this looked at.
Going back into the shop this coming Monday - will update when I have some information back.
Spent 3 hours at the shop today.
No air in the lines. No loose oil plugs. No metal pieces in the gear oil. I don't think it helped that I'd driven an hour to get there, and the warmed up gearbox was shifting better. The mechanic suggested it could be down to the change of gear oil at the last service. Because the old stuff was very gluggy perhaps the gearbox wasn't as 'smooth' with the new stuff. I offered to leave the 110 there overnight so they could experience the very difficult changes when it's cold but he said there wouldn't be much point - because they couldn't identify anything they might have done to cause it initially, or any problem that didn't involve pulling the whole thing apart at my cost to see if a new gearbox was necessary. He said there was no risk of mechanical damage (or further damage?) from driving it around and seeing how it went, and they replaced the gear oil again, free of charge to see if it makes any difference. So let's see how it goes over the coming weeks. Thanks again for the various suggestions. |
| Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3788
Sounds like a bit of a cop out from the mechanic. See how it goes with the gear oil I suppose. Is you mechanic an LR main dealer? Is it still under warranty?
@Co1 They're a Land Rover specialist mechanic with a good reputation around my city and state. Been going there for 3-4 years for servicing - this is the first time I've had an issue, so it's a bit of a 50/50 situation in my mind at the moment.
It's about 3 months out of warranty... Hahaha! As you'd expect. |
What oil went in?
Did they measure out 2.2 litres of oil rather than “fill to spill”? |
Good question. I think they use Penrite, but I didn't think to ask about whether they used correct measurements or filled to the brim.
| boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 751
Have you tried driving it in low ratio? I'm just wondering if the transfer box may not be quite aligned and causing issues in low gears that are more noticeable than high gears. A bit of a longshot, but maybe worth a check.
@boxoftricks
That's actually worth a go, cheers. I thought it might be some misalignment originally, and rowed it through the various gears while stationary - but I haven't taken it somewhere with some loose or uneven terrain and driven it in low range. Will give it a try this week. |
| All times are GMT |
