Home > Maintenance & Modifications > Shocks and springs what ones?
bear100
A topic which has come up many times i expect......but it is a forum!!
Shocks? what are your preferred? and why.
Springs? same as above really. longer travel? shorter?
Im am currently building an overland spec 110 for an upcoming trip, my springs and shocks are the originals and 9 years old with 50k under their belt.
i will want a good mixture of road and off road performance (mostly on road) and can handle the extra weight of the kit
Suggestions....Koni? good reviews......Bilstein B6 also good reviews
Thumbs Up 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #777780 17th Jun 2019 7:13am
Personally I'd probably go the OME route, with the details dictated by the anticipated load and planned usage.
Post #777786 17th Jun 2019 8:12am
IGP
As above, go the OME route (Original Manufacture Equipment) and if needed some Air helper springs.
Ivan
Post #777787 17th Jun 2019 8:15am
Sorry, I should have been clearer !
OME = Old Man Emu.
(OEM = Original Equipment Manufacturer).
I'd go for the Old Man Emu solution.
Post #777788 17th Jun 2019 8:22am
roel
I would go for the adjustible Koni shocks.
Springs I don't know. I have Britparts now and they are OK but the paint is off so the look rusty. Roel
2003 90 Td5 (2009-now)
Post #777790 17th Jun 2019 9:03am
hank
More often than not people just recommend the ones they have fitted... As I will!
I have nothing much to compare them to other than the knackered OEM dampers that were previously fitted but I have been very happy with my Fox dampers. They are the manufacturer of choice in many competitive motorsports so can't go wrong in my opinion.
Springs, I guess it's down to personal requirements and specifications but there are all manner of springs available on the market so you will find something suitable > 110 XS Double Cab
Post #777801 17th Jun 2019 10:10am
bear100
I had Old Man Emu on my discovery a few years back and they were great but this overland is a different build altogether.
Hank your right most people will give opinions on what they are running and have no other comparison compared to the knackered units they took out.
Shocks vary widely, Koni have a huge diameter barrel compared to others, Old Man Emu build doesn't seem as good as Bilstein then theres the Bilstein B6 with ride control, Fox is another one added to the list to look into.
Springs on the other hand dont seem to have the same sort of passion about them compared to shocks, my last 90 i added the 2" extra lift springs and regretted it, i dont think i want to go down that route again....unless they are a must have for overland due to weight etc. 2023 Defender L663 V8
Post #777802 17th Jun 2019 10:34am
rallysteve
Have seen a lot of OME defender dampers with the ends sheared off from normal use, not even overland.
My personal vote would be Bilstein.
Post #777808 17th Jun 2019 11:27am
^^ Interesting, not good.
Post #777809 17th Jun 2019 11:36am
Roy5695
Give Gwyn Lewis a call. discuss the type of weight you are going to carry and they will advise from there. What they don't know isn't worth knowing. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #777811 17th Jun 2019 11:57am
jst
I run several defenders and have modified plenty more and rechassied 8 or so. I have seen and tried various combinations over the last 15+ years from overlanding , to trials to greenlane to full on comps.
I have tried, ome, oem, koni, blistein, procomp, britpart, king, fox through leafs, coils and coil overs.
I run my 110 overlander usw on std springs, with rear air helper and ome shocks. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #777824 17th Jun 2019 1:00pm
I've just changed my rear springs, and the 110 now handles like a dream.
Have HD LR front springs (normal LR ones, 90 rears/110 HD fronts)
Military wolf 110 rear springs.
OME dmpers all round.
I thought the rear springs would be too hard but with some kit on board (and my 110 has a full cage) its really nice, and gives a nice "rear end up" stance.
Post #777844 17th Jun 2019 2:39pm
bear100
I have heard a few gripes about the welds on the OME shearing off as mentioned, shame because they were my go to choice.
Air helpers? umm sounds interesting ive seem them a while back but totally forgot about them....any one use them on here? 2023 Defender L663 V8
Post #777852 17th Jun 2019 3:35pm
8619simon
Wales 1995 Defender 110 300 Tdi CSW Epsom Green
I have a 300TDI 110 CSW built up as an overland vehicle. I try and run as light as possible but still carry a bit of weight with water tanks and a long range fuel tank, the following has worked very well for me for the last 4 years with about 15,000 miles off road in Pyrenees, Morocco and Western Sahara:
Shocks: Koni Heavy Track - Adjustable with setting one off softest
Springs: Front - Standard Height Land Rover Springs - NRC8044/8045
Springs: Rear - Standard Height Progressive Springs - RKB101111
I don't have a winch fitted but have fitted Air Lift Helper springs on the rear when I am very loaded on trips with the family with all the toys!!
Set up works really well and has performed faultlessly on and off road including long sections of desert and corrugations in harsh terrain.
Post #777869 17th Jun 2019 4:42pm
I'll have a set of 110HD/130 dual springs up for sale soon (with the smaller inner spring)
These ^^
Post #777918 17th Jun 2019 9:09pm
