Home > Puma (Tdci) > Coolant change and sump rotten |
Iktank Member Since: 08 Nov 2014 Location: Porthcawl Posts: 236 |
Todays job was to be change the coolant - empty and refill but......
Sump had a damp spot on pressing it with a screw driver it went thro and oil came out , 2014 2.2 puma with only 36,000 miles So replaced the sump today took me 3 hrs, and luckily the oil was due for replacing this month anyway Back to coolant, which will now be tomorrows job....... Where do I drain the coolant from, I note the manual states pull off hoses from fuel cooler but i do not have a fuel cooler which is there on the 2.4 puma and some early 2.2 puma advise would be appreciated Ta Ian Last edited by Iktank on 14th Jun 2019 7:26am. Edited 1 time in total |
13th Jun 2019 6:13pm |
G4V JW Member Since: 24 Sep 2018 Location: Northants Posts: 190 |
Going to check mine now Instagram; @gavin_walding
13th Jun 2019 7:35pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19452 |
Lucky escape. Dinitrol it. You can use the thermostat hose as a drain point. It’s quite deep up in there and the clip can be stiff. Work the clip off and keep the hose on. Use proper PPE especially eye protection and when your ready take off the hose to drain with suitable container ready to go. You really need the WSM as this contains the draining and bleeding procedure on it. Diesels Lives Matter. ⛽️🛢️👨🔧🧰⚙️
And if You Love the Country, then we’re on the same side ~ I got’ love for Britain, I got’ British pride’. 🇬🇧 |
13th Jun 2019 7:48pm |
13th Jun 2019 8:03pm |
cheers
14th Jun 2019 11:13am |
UtilityTruck Member Since: 09 Jan 2014 Location: Oxford Posts: 463 |
What?! This is a fairly shocking performance, even on a Land Rover. 5year old sump, as good as rotted through? What the hell were they making them from? Let’s not forget the inside is quite adequately rust proofed due to its total immersion in oil, so any rust is just from the front where the smooth flat surface shouldn’t exactly promote rusting.??! 2014 Keswick Utility 2.2
14th Jun 2019 7:57pm |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
I know it's totally when you think about it. A hole in the sump at that age. Landrover above and beyond.... 😬
14th Jun 2019 8:04pm |
Damn good job it didn't let go miles away from home that's for sure. Diesels Lives Matter. ⛽️🛢️👨🔧🧰⚙️
14th Jun 2019 8:16pm |
