Home > Puma (Tdci) > Coolant change and sump rotten
Iktank
Wales 2014 Defender 90 Puma 2.2 SW Corris Grey
Todays job was to be change the coolant - empty and refill but......
Sump had a damp spot on pressing it with a screw driver it went thro and oil came out Sad , 2014 2.2 puma with only 36,000 miles
So replaced the sump today took me 3 hrs, and luckily the oil was due for replacing this month anyway
Back to coolant, which will now be tomorrows job.......
Where do I drain the coolant from, I note the manual states pull off hoses from fuel cooler but i do not have a fuel cooler which is there on the 2.4 puma and some early 2.2 puma
advise would be appreciated
Ta
Ian
Post #777377 13th Jun 2019 6:13pm
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
Thanks. My 2014 110 has a rusty patch on the sump I was going to treat. I'll approach it with more trepidation now.
Sorry I can't answer your coolant question incidentally.
Post #777390 13th Jun 2019 7:28pm
G4V JW
Going to check mine now Shocked Instagram; @gavin_walding
Post #777391 13th Jun 2019 7:35pm
Lucky escape. Dinitrol it. You can use the thermostat hose as a drain point. It’s quite deep up in there and the clip can be stiff. Work the clip off and keep the hose on. Use proper PPE especially eye protection and when your ready take off the hose to drain with suitable container ready to go. You really need the WSM as this contains the draining and bleeding procedure on it. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #777394 13th Jun 2019 7:48pm
dorsetsmith
Post #777397 13th Jun 2019 8:03pm
Iktank
cheers
Post #777453 14th Jun 2019 11:13am
UtilityTruck
What?! This is a fairly shocking performance, even on a Land Rover. 5year old sump, as good as rotted through? What the hell were they making them from? Let’s not forget the inside is quite adequately rust proofed due to its total immersion in oil, so any rust is just from the front where the smooth flat surface shouldn’t exactly promote rusting.??! 2014 Keswick Utility 2.2
Post #777542 14th Jun 2019 7:57pm
williamthedog
I know it's totally Censored when you think about it. A hole in the sump at that age. Landrover above and beyond.... 😬
Post #777544 14th Jun 2019 8:04pm
Damn good job it didn't let go miles away from home that's for sure. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #777548 14th Jun 2019 8:16pm
