Home > Technical > Transfer box leaking.
Roy5695
Hope the picture shows properly. My transfer box is leaking from the area just above the filler hole. Think this is the end of the intermediate shaft?! Any help would be much appreciated towards a fix for this problem.
 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #723836 16th Aug 2018 5:26pm
Roy5695
solved this myself this weekend, transfer box off, shaft pushed back, o-rings replaced and sealant applied. back together and fingers crossed it won't leak again! 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #741224 19th Nov 2018 1:11pm
hank
Has it stayed leak free? > 110 XS Double Cab
Post #775401 29th May 2019 9:59am
Roy5695
It is still leak free! Thumbs Up
Although that’s jinxed it now 😂 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #775440 29th May 2019 4:48pm
Same with mine (although it was leaking at the other end of the shaft)
PITA to take the transfer box off for a 2 pence seal though.
Post #775477 29th May 2019 9:58pm
Roy5695
Did mine while I had the box out to do the clutch. Cool 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #775485 29th May 2019 10:11pm
Those of you who have done this, can you tell me how you went about setting correct bearing preload for the intermediate gear?
Post #775523 30th May 2019 10:13am
Roy5695
Piece of string, spring balance and some dodgy maths. There’s a Bearmach video on YouTube that demonstrates it much better than I could explain it. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #775642 30th May 2019 11:23pm
