Home > Td5 > Bottle Jack
Page 1 of 3 123>
RANGER1312
United Kingdom 2001 Defender 90 Td5 CSW Stornoway Grey
Bottle Jack
Hi all,
I've been doing a number of jobs on the 90 recently and noticed that it doesn't have a bottle Jack or any other accessories if they come with them (my 2 td5 discoverys bith came with bottle jacks, wheel chocks and removal tools).
I've done a search and the standard LR bottle Jack seem to have mixed reviews regarding quality etc.
Are there any recommended alternative ones whether later model or aftermarket ones?
Do I need to get any equipment / parts to fix it all in with so its not hitting into the battery when driving?
Thanks
Nick
Post #775457 29th May 2019 8:30pm
People buy a disco 2 bottle Jack and find somewhere secure to keep it.
I buy Mercedes Sprinter bottle jacks, similar, but better. QRZ 2e0vpf
Post #775462 29th May 2019 8:55pm
RANGER1312
Thanks Greeni, do the Mercedes Sprinter ones not fit in the seat box?
In what way are they better?
Post #775465 29th May 2019 9:07pm
They're more heavy duty. Not tried to fit it in my seatbox, one side is full of fuel tank, the other electrical science. QRZ 2e0vpf
Post #775473 29th May 2019 9:39pm
RANGER1312
Ah makes sense Laughing I'll see if I can get the measurements for one and hopefully it'll fit Thumbs Up
Post #775475 29th May 2019 9:46pm
Re: Bottle Jack
The standard LR bottle jack is exactly the same as that issued for the Disco 2. Perhaps your thinking of the Defender pillar jack, which is complete rubbish? Darren
Post #775484 29th May 2019 10:08pm
Ihod
United Kingdom 1998 Defender 90 300 Tdi ST Rioja Red
Mercedes Sprinter and VW Crafter bottle jacks have the same saddle type axle support as a Disco or Defender jack and are usually rated by 1 or 2 tonnes higher capacity.
Very often available much cheaper on Fleabay..... Ian
MY1998 300Tdi 90 Hard Top (Now Soft Top)
MY2015 110 XS SW - Sold
MY2008 110 County USW - Sold
MY1962 Series IIa Truck Cab - Sold
MY1994 300Tdi 90 Hard Top - Sold
MY2001 TD5 90 Truck Cab - Sold
Post #775488 29th May 2019 10:49pm
Those Merc ones aren't any good if you have a flat tyre, which is kind of important! Due to the body size. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #775489 29th May 2019 11:11pm
RANGER1312
Hi LRA, thinking about it, it was a pillar Jack that was getting the mixed reviews.
Steve when you say body size do you mean size of the actual Jack i.e. it won't give you the height required to lift a defender?
Do the Mercedes ones come in different sizes maybe?
Post #775501 30th May 2019 7:00am
VVS210
I think he means the body is taller so won't go under the axle if the tyre is flat. That's easily solved though, put your spare in front of the flat & drive up onto it, once the wheel is jacked up enough you can slide the spare out & swap them over - an old off roaders trick Thumbs Up
Post #775505 30th May 2019 7:47am
In my experience, it just works. I had a flat on the offside, i.e. the thicker end of the casing, of my old 90 and was able to squeeze a Sprinter jack under the axle casing to change the wheel. Darren
Post #775512 30th May 2019 8:58am
Yes, the Merc version is a bit taller. That doesn’t mean it’s no good but can give you a few issues as mentioned above.
How much height they extend though and how they compare I don’t know.
Personally I’m quite happy with the LR version. Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #775535 30th May 2019 12:01pm
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
I bought a new sprinter one, picked up on eBay for £35 👍
Post #775547 30th May 2019 1:51pm
SteveK
United Kingdom 2002 Defender 110 Td5 HT Rimini Red
The Merc jack is just the right size to fit in the battery box, and the handle (borrowed from a trolley jack) fits neatly alongside.
No problems lifting my 110 with a flat.
Post #775753 31st May 2019 10:43pm
RANGER1312
Thanks for the replies guys, really appreciate it Thumbs Up
Good to know that it will fit in the seat box and thanks for the heads up on the off roaders trick Cool
Post #775803 1st Jun 2019 3:13pm
Page 1 of 3 123>
