Landymatt Member Since: 31 Dec 2018 Location: York Posts: 204 ![]() ![]() |
First camping trip of the season. Just a hose pipe in a field.
But a fire pit, melted chocolate and strawberries to dip keeps everyone happy. ![]() Click image to enlarge |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3769 ![]() ![]() ![]() |
^^^ I assume the kitchen sink is in there somewhere? π
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6029 ![]() ![]() ![]() |
Removed front prop and checked UJs and while off I greased the nipples - Part of the hunt to try and solve the wheel wobble issue (55-60mph) - some roads worse than others
Rear wheels balanced up OK as are the fronts and the tyres are OK. No play in ball joints according to the garage who had a look. Started making the mounting plate for the Eberspacher from some stainless I had hanging around. Modified the rear corner protectors I got and now these are in for blasting and powder coating. Took the rear chequer plates covers off also for blasting and coating. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
Hi John, have you checked the front panhard rod bushes, and or checked the bolts for tightness? QRZ 2e0vpf
Hi Greeni.
Replaced the bushes with gen LR ones along with new bolts/nut and same for the radius arms (all bushes and buts/bolts) - maybe a retorquing/checking would be an idea. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
My v8 became vague this past couple of weeks, was the panhard rod bolt slightly loose.
Worth a try ![]() |
certainly worth a poking with a Mr T. Orque wrench. 1999 Defender TD5 110
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20978 ![]() ![]() |
Have a look at the steering box drop arm area that there is no play and the steering column UJ too.
Also although may not seem associated damper bushes too, they can cause all sort of feedback issues whilst driving. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Whats the best way of checking UJs? just wiggle steering wheel left/right
I did think about the shocks - will also have a look at them & bushes 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3862 ![]() ![]() |
Sorted my front lower a/c grill with stainless grill & fixingsand fitted some modern style indicatorsπ
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Indicators are dark smoked led Knight rider style... I think they are great π ![]() Click image to enlarge |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3357 ![]() ![]() ![]() |
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 ![]() ![]() ![]() |
Love it πππππππ
Drove to the Cheshire Landrover experience for a drive around their grounds. Unfortunately the defender we booked to use had broken so we ended up using a disco 5 which is very capable but Iβll stick to the defender
![]() ![]() My build thread http://www.defender2.net/forum/topic17615.html |
