![]() | Home > For Sale & Wanted > [Wanted] 1.4 Defender Ratio LT230 Transfer Box |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
Hi all,
Now my 90 V8 project is on the road, we have realised that the gearing is a little long with the higher ratio V8 5th gear, 1.2 ratio transfer and 255/85 tyres. Therefore I am looking for a good condition (Td5 if possible) 1.4 ratio transfer box to put in instead. Does anyone have on lying around after doing the opposite swap? Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread Last edited by rallysteve on 28th May 2019 8:20am. Edited 1 time in total |
Bump, still looking.....
Steve 02' 110 TD5 Double Cab Rebuild Thread |
Still looking for a standard 1.4 ratio Defender transfer box. I will consider a tdi age box but would prefer a td5 one. Surely someone must have one they have removed to fit a higher ratio 1.2 Discovery transfer?
Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6705 ![]() ![]() ![]() |
The issue might be that you need to rob bits from the 1.4 box to fit to a D2 1.2 box, so (for example) I've been left with a 1.4 box but it's incomplete - no rear housing, no brake drum.
