![]() | Home > Technical > Redbooster clutch slip |
Timo K Member Since: 23 Aug 2012 Location: Helsinki Posts: 171 ![]() ![]() |
Could just be your clutch is gone..?
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2389 ![]() ![]() ![]() |
Or more likely that it's been poorly adjusted.
Not_Given Member Since: 25 Dec 2017 Location: UK Posts: 96 ![]() ![]() ![]() |
Timo,
A fair point given Puma clutches, but no slip on the run immediately prior to install. Anyone know whether air in the hyds would show as slip. I’m not as familiar as I know I should be. If it is clutch I’m assuming a ClutchFix replacement is the sensible choice? NG Edit: Thanks, Mo. Hopefully that’s the issue |
To anyone stumbling across this thread in the future:
My clutch slip was due to a failing slave cylinder and not related to the Redbooster at all. I’ve just returned from some great driving in the Lakes and I am thoroughly impressed with the Redbooster and how much it helps ease the pain of sitting in Bank Holiday traffic! NG |
Glad it was a relatively easy fix 👍
Top job coming back to report in!
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5353 ![]() ![]() |
My dad learned this the very hard way. he decided to change the full smash, but never bothered to check the pedal, burnt the full works, so he had to buy twice! Laugh was all it needed was a master cylinder change in the 1st place
![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
