Home > In Car Electronics > Double din shortlist! |
PCM Member Since: 25 Jan 2019 Location: North East Posts: 854 |
Hi Andy
For the facias you have 2 main types: There are ones are where you have to cut the top off (vents) and re-glue the sticky labels on. These can be great quality, but are a pain to fit as you need to trim the original dash vents and clock. (Probably ok for a pro, but not me) The second type has the vents and stickers built in. Easy install and look great. Morte plug and play. I'm ignoring the first type as it's hard work and the installer you pick will complain or charge you a lot, so for the second type costs vary. I've seen them on Flabay for £150 but was warned by an audio garage that they have seen some of really bad quality, hence i stayed away from these ones just in case. The best ones are apparantly from Twisted but are £570 https://twistedautomotive.com/store/double-din-panel/ I have one from defender upgardes that is in my mind the same quality as the rest of the dash. TYou should be abel to get everything fitted in a morning if you choose the easy bits (Like me) and the cost of everything all in should be under a grand. Good quality but hard work type! https://www.4x4overlander.com/product/double-din-console-2/ Easy type: With vents: Others available! Click image to enlarge http://defenderupgrades.co.uk/product/doub...air-vents/ See my suggestions for other bits, but i'd buy them from the installer as you get a warranty from them that's easier to fix if things come loose, plus the prices are about the same as they make a proffit from buying wholesale and tend to keep the prices competitive.. They normally just insist you buy the double din bit. Any installer should be fine, as it's an easy job. Hardest decision is where to put the rear view camera, and that depends on what you want to see. Good luck PCM |
21st May 2019 10:58pm |
andy---doe Member Since: 14 Mar 2015 Location: Yorkshire Posts: 188 |
Hi PCM
Thanks for the detailed response. I will go for the Defender upgrades facia but I very much doubt I will do the fitting. As you say, I will probably purchase the other bits from the installer – when I find one. Rear camera is already in situ (as this upgrade is replacing a pop out Clarion unit that has the camera/sat nav, etc) Regards Andy |
22nd May 2019 8:16am |
Bluericky Member Since: 26 Jun 2014 Location: Cornwall Posts: 647 |
Andy
It really is very easy to fit , gove it a go yourself and if you go for the half depth units (I didn’t !) the it will be even more of a breeze . My defender is the “poverty spec “ so I got away with out having to install the second panel and cutting the dash . I relocated the Hazard switch to the headlight level recess on the new fascia . A bit of fretting and it clicked in ! https://www.instagram.com/hustynminepark/ |
22nd May 2019 8:25am |
Andy
If you already have the camera then serioulsy it's literally a few hours playing about. There is a youtube video of a bloke installing it that lasts for 20 minutes. He's never done it before either. It's 2 torx bolts and a bit of popping off switches. No cutting of wires. Take photos and go for it. You'll be so proud of yourself. |
22nd May 2019 8:42am |
Bluericky
It may be easy for Landy people that enjoy tinckering - but I can't even see how the existing Clarion unit slides out!!! (Old car radio/stereos used to need a double pronged hairgrip like gadget - but this Clarion doesn't) I realize I wouldn't necessarily need to remove the Clarion unit and could just take the facia off - but that may be the beginning of my troubles! I assume the facia comes of by unscrewing the two Phillips screws and then just pulls away? |
22nd May 2019 8:43am |
PCM
Just seen your post. I may have a look at You tube, but probably still erring towards buying the unit from a car audio shop and letting them do it. |
22nd May 2019 8:46am |
Mine from Defenderupgrades with orientable vents
Click image to enlarge Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
22nd May 2019 10:09am |
You’ll need the stereo removal tools for your particular make and model or as you correctly say , just remove the torque screws along with entire fascia and unplug all electrics . 20 minutes to get it out and that’s allowing a tea break !
Fair enough though if you get the pros to do it but as above poster says , there’s a lot of satisfaction and a boost in confidence if you do it yourself . Feeding in the auxiliary usb, handsfree mic and GPS is what takes the most time in order to make a tidy job of it and does involve feeding it through the sides of the dash . There’s also a handbrake earth wire so the system knows if you’re at a standstill (health and safety!!) and also wiring for the reverse camera in order for it to actuate (I haven’t done this as reversing isn’t a problem!) Rich https://www.instagram.com/hustynminepark/ |
22nd May 2019 10:20am |
I would definitely go for the defender upgrades version as it’s a far easier , less time consuming and tidier job. I wish I had https://www.instagram.com/hustynminepark/
22nd May 2019 10:22am |
The plus are the orientable vents, no more ice on my and passenger shoulder Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
22nd May 2019 10:36am |
Mev247 Member Since: 21 Feb 2019 Location: Wilts Posts: 49 |
Thanks for all the input chaps sorry for the delay Ive been away. So the fascia I ahve bought is below..... I think the sigle deck double din is the way to go so Im just unsure which is best. I think I want the Nav on it so I dont have to mess around with phones overseas etc.... so I guess the search begins and then attempt a fit...
Click image to enlarge 60 110 XS -61k- Corris - For Ever.... |
22nd May 2019 12:29pm |
Can I ask a daft question how do you use the sat nav or maps in conjunction with this unit or any other unit compatible with an iphone? Im thinking 400 quid on top of this just for nav when you can do it on the scree via phone might be more suitable... value for money. Must be able to do in Europe though... Thx 60 110 XS -61k- Corris - For Ever.... |
23rd May 2019 1:10pm |
It's really simple.
You just click on apple car play on the screen when your phone is plugged in. This brings up all the Apps that are car play enabled. Basically it turns the car stereo 7" Screen into a big Iphone touch screen. You have a choice of Apple Maps, Waze, google maps etc.. Plus all the music apps. Spotify etc..that are iphone emabled. Then i just speak to it or use it as you would your iphone with the touch screen on the stero unit. Works well. The reason i like it is you get the latest maps all the time from Googles database. It uses use your data though, but If you know where you are going you can download maps to be used Offline using the google maps app from your home before you set off. I have the North East UK downloaded offline. It's a tiny file. Waze is good too, but has too much clutter on it for me. Google are starting to put speed camera locations on it too soon so it's also a speed camera trap locator. Not that you can speed in a 110. The official sat nav units are unfortunately expensive. If you don't want to have your phone connected then you need to buy the Nav GPS antenna and compatible Nav unit. I couldn't justify this extra cost. |
23rd May 2019 10:40pm |
Ok I think Im going to go for either the Kenwood or the Sony option that have car play. Can I ask is it easy to fit a USB cable at the same time as I assume the phone has to be connected to it via this so all the maps and music can be play on screen? Assuming this is just a clear mirror image of your phone screen? 60 110 XS -61k- Corris - For Ever....
24th May 2019 8:14am |
