![]() | Home > Puma (Tdci) > Glow plug faulty - replace one or all of them? |
MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 260 ![]() ![]() ![]() |
I replaced mine last year (at 7 years old) none of them were working! only one got luke warm, the rest did not.
Do them all. Twist / turn them as you pull / lever them out. 1953 80" 1987 mini city e 2011 90" |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6331 ![]() ![]() ![]() |
so with none of them working how bad did things get?
what I mean is with one not working do you even notice. if not this should be considered against the potential problems caused should it shear off while trying to remove it? |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
All it’s not an easy job
Maybe a second or two slower to start in the winter but I didn't even realise. I wanted to clean the inlet manifold of muck and thought to do them at the same time as they are not expensive.
I found it easy but then am good with the spanners! 1953 80" 1987 mini city e 2011 90" |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20824 ![]() ![]() |
Shouldn't there be DTC's logged with glow plug faults? Obviously no MIL or you'd have noticed.
I thought they were on the radar so to speak with ECU monitoring. _\Hennessey|Venom| F5/___ ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2469 ![]() ![]() ![]() |
Are glow plugs really needed on moderate climates? Puma 110" SW
