Home > Technical > Td5 crank sensor o ring part no?
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
Bought a used genuine crank sensor on eBay for my td5 to keep as a spare in the car. Was going to test it to make sure it’s functional but it hasn’t come with an o ring, anyone know the number or if where I can get one?
Post #773290 15th May 2019 8:52pm
dorsetsmith
O ring is part of the crank sensor build no part number
Post #773293 15th May 2019 9:11pm
htb2
Wales
Use the one off the one you take out when you replace it. Or take it out and measure it and order from one of the many suppliers on the net.
Post #773304 15th May 2019 10:10pm
Vogler
Belgium 2015 Defender 110 Td5 HT Chawton White
Is the metal plate NSJ000010 what you mean? I have a both the sensor and NSJ000010 in unopened packages and I don't see any rubber O ring.
J Antares Treadwell, a MY06 110 Td5 in Chawton White
Post #773316 16th May 2019 6:12am
bankz5152
Buy a pack of quality nitrile orings. One will fit
Post #773344 16th May 2019 10:26am
LandymanStefan
Well interestingly I’ve been looking into it and none of the genuine ones have one but most of the aftermarket ones do.
So makes sense that my genuine one doesn’t.
The green o ring on the aftermarket one vs the slot on the genuine pictured
Post #773408 16th May 2019 8:05pm
Vogler
Why would an O ring actually be necessary there? Antares Treadwell, a MY06 110 Td5 in Chawton White
Post #773428 16th May 2019 9:07pm
michaelwl
South Africa 2002 Defender 110 Td5 SW Alpine White
I've just bought a genuine one from a LR dealership here in South Africa and mine came with the o-ring already fitted. 2002 110 TD5 White
1981 S3 R6 Matt Green - Now used as game viewer
2013 Discovery 4 XS
Post #773586 17th May 2019 4:12pm
