Home > Maintenance & Modifications > TDCi Air Vent removal
Rugbyball
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
Hi All
Can anyone tell me if it is possible to remove the two central round air vents on a Puma without removing the facia? Can you get them out from the outside?!
If so, any tips on how to do it? I want to replace the vent inserts (louvre assembly)
Thanks! 2015 Overfinch Defender XS 90
1998 50th Anniversary V8
1989 90 CSW
Many Discoveries...
Post #772957 13th May 2019 5:58pm
The whole things comes out, then remove the rings.
Ideally best removed from the rear to avoid stressing the Louvre assembly. They are a push fit, nothing to remove or un-clip.
Then the rings can be took off and un-clipped from the Louvre assembly once removed. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #772958 13th May 2019 6:09pm
hank
Yes. Give them a tug. If you are replacing then these are the very same as fiesta units > 110 XS Double Cab
Post #772961 13th May 2019 6:20pm
Yep, 2006 - 2010 Ford Fiesta I think.
They can be bought for far less money and are identical. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #772975 13th May 2019 7:30pm
Rugbyball
Thanks guys.
I was thinking to replace them with the Mercedes A class fitments (yes, I know.....but I saw them on JE’s Zulu).
So a tug and they should pull out far enough that I can get in to release the holding pins?
I will have a gander at the Fiesta ones also.
Thanks 2015 Overfinch Defender XS 90
1989 90 CSW
Many Discoveries...
Post #773019 13th May 2019 9:27pm
Zed
I looked at the Merc ones a while back but couldn't find any cheap enough to take a punt on. Have you seen them fitted in the flesh?
Post #773048 13th May 2019 10:21pm
PCM
Following this with interest. Thumbs Up
Post #773059 13th May 2019 11:30pm
Never seen those A class vents before.
Yes, just pull the whole thing out and then you can get to the clips at the sides for the rings.
The whole vent will come out including the rings but ideally you need to get to the back to just push it out.
I would not try and prise it out as there is no need as it’s a push fit with a foam seal to the air vent duct behind.
It’ll go back in just as easy. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #773124 14th May 2019 3:18pm
Rugbyball
Thanks Pal! Thumbs Up
Will update on how it went soon..... 2015 Overfinch Defender XS 90
1989 90 CSW
Many Discoveries...
Post #773126 14th May 2019 4:20pm
Shoukd be of interest to some of you? Wink
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #773135 14th May 2019 5:02pm
Rugbyball
Really helpful to see it Steve....thanks.
At first glance they look shorter than the Merc ones, so will be interesting to see if there is enough space. Diameter on the Merc surround exterior rim is 4” which I think is doable.
Cheers mate.
1989 90 CSW
Many Discoveries...
Post #773158 14th May 2019 8:12pm
Rugbyball
Well....after taking ages to get around to do doing this modification....I finally managed to finish it!
So this is just for those who have thought about this particular change!
Took a little bit of creative fitting but the new vents are in. Always a bit tricky when you are not 100% sure how to get the Defender ones out and these to go in.
Two Mercedes GLA air vents are now in place.....and I think they look really good and just like the JE MotorWorks Zulu!!
On now to the next modification..... Very Happy
1989 90 CSW
Many Discoveries...
Post #796345 2nd Oct 2019 3:52pm
Stacey007
Merc A Class ones on mine.
Need to trim them a bit more to get them further in but I like them, seem to work well aswell with more control over the air...
Post #796347 2nd Oct 2019 4:19pm
Rugbyball
Nice look! Thumbs Up 2015 Overfinch Defender XS 90
1989 90 CSW
Many Discoveries...
Post #796349 2nd Oct 2019 4:24pm
Roy5695
The new merc sprinter ones fit too and look lovely. Good work. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #796380 2nd Oct 2019 7:32pm
