Home > Puma (Tdci) > Software Updates
defender75
2009 Defender 110 Puma 2.4 XS CSW Chawton White
Software Updates
Is there anyway to get dealer software updates without going to the dealer?
Post #76909 20th Jun 2011 11:42pm
K9F
Not unless you got the tools to do it!! How would you get the update into the vehicle and check everything was running ok? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #76962 21st Jun 2011 11:37am
DefenderOfTheEarth
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Maybe some indys have the kit?
I use one for the BM - they do exactly the same as the dealer for half the price - full diagnostics, update service interval on the OBC and they can get all historical data by reading the key.
I should think DIYing it is near impossible without a load of pricey kit. Defender 110XS SW gone... now VW California 180 4 Motion.
Post #76980 21st Jun 2011 1:48pm
defender75
BM?
Post #77014 21st Jun 2011 5:58pm
kingofthesparks
Location: Very close to Watford gap services , northants
United Kingdom 2012 Defender 90 Puma 2.2 HT Fuji White
From germany and not sure what a BM is Shocked
Post #77016 21st Jun 2011 6:00pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
BM = ?? Basic Maintenance. Wink LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #77018 21st Jun 2011 6:10pm
Lorryman100
Re: Software Updates
It is easy to do, just buy this:
http://www.budgetdiagnostics.co.uk/ford/ge...2mtsbi9pg7
It comes with access to the latest upgrade files Thumbs Up
Post #77020 21st Jun 2011 6:10pm
DefenderOfTheEarth
Bavarian Motor (Works) innit.
Or Bayerische Motoren (Werke) if you're actually German. Defender 110XS SW gone... now VW California 180 4 Motion.
Post #77028 21st Jun 2011 6:35pm
Glynparry25
Maybe try talking to someone like Gary at Alive. Maybe he can sort you out by using the ATRIC?.... You could also get a modified map too at a fraction of the cost of the type Bri has linked.
Glyn Dog Sheep
Post #77029 21st Jun 2011 6:42pm
defender75
Thanks for the info. Sorry not German just there for work most of the time. I appreciate the info. Will talk to Gary as I wanted to do a remote remap as well.
Post #77041 21st Jun 2011 7:50pm
bell-auto-services
Hi
Ill add a little info to help.
To have a software update correctly installed on the car a remapping tool will just not work as the update was intended from landrover, The Dealer VBF files used to make a correct ecu software update are in 3 parts not 1 as used in all remapping tools.
The remapping tool only programs PART of the ecu where the mapping structures are stored and a small part of the base ecu software, The main software of the ecu is not changed when a remapping tool is used hence why they dont add programming records Smile
You will need something like a Blackbox Soloutions Faultmate MSV2 "with built in remote remap capeability" if you require it, or Autologic possibily or as already said above an IDS/SDD dealer level tool.
After the calibration update is done it then needs a pilot correction update, this will need to be compleated to finalise programming correctly which makes the running and efficency of the particular cars injectors and fuel pump match the new calibration update programed into the ecu. Typical something that a lot of dealers mis or fail to complete correctly after a program as most are so pressed for time.
Pete
Post #77215 22nd Jun 2011 10:18pm
defender75
Thanks for the info. I guess I will get the dealer to do the update but of course now I am worried they won't do it correctly.
yikes
Post #77230 23rd Jun 2011 4:47am
defender75
yikes
Post #77231 23rd Jun 2011 4:51am
K9F
defender75 wrote:
Thanks for the info. I guess I will get the dealer to do the update but of course now I am worried they won't do it correctly. yikes
I had numerous issues with a software update and subsequent incompatability issues with my Autologic remap...Even when done correctly it can highlight other issues...
http://www.defender2.net/forum/topic3243.h...patability
Software updates can be a bain, and eat up avaliable slots in your ECU! I no longer have software updates. People in my opinion rush to have them because they are free....and they think their vehicle will perform like a Formula 1 car afterwards, I did!!!
I work on the principle if your vehicle is running sweet and you are happy with it and there are no major mechanical or safety issues....If it ain't broke it doesn't need fixing!!!! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #77296 23rd Jun 2011 2:15pm
