Home > Td5 > Post MY02 rear door maintenance, modifications or upgrades? |
The post '02 rear door is a pretty well sorted package. The only mod I can think of that would be worth doing whilst it's in bits would be to fit a time delay relay to the rear wiper.
When I rebuilt one for my old 90, I also fitted two large aluminium backing plates to the spare wheel carrier to stiffen up the mounting. If you're fitting a separate carrier though, that won't help you. Click image to enlarge I suspect that a separate carrier will also negate the need for a door gas strut. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
8th May 2019 7:27pm |
RANGER1312 Member Since: 04 Feb 2018 Location: Fylde Coast Posts: 125 |
Thanks Darren, I didn't know if the gas strut would still be needed with the swing away wheel carrier.
I've recently purchased a .99 relay for the front wipers, would the old one from the front work in the rear or do I need a different one? |
8th May 2019 7:38pm |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1829 |
Is the standard post-2002 door stay different or improved from earlier ones?
I only ask because I had a separate carrier on my door (Tdi) and the door would still swing shut on me. I think I should have fitted a Naka strut years ago. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
8th May 2019 7:57pm |
It is essentially the same design. When I fitted a post '02 door to my '92 90, I was pleasantly surprised that it bolted straight on. Darren
8th May 2019 8:00pm |
I suppose the wheel carrier will take the weight off the door and make it easier to open and close where the strut will stop it closing on the kids when they're climbing in and out...
8th May 2019 8:44pm |
Well, I think that proves my point!
I had a problem for years with my door closing on me, even with the wheel on a swing- away carrier. If the design is essentially the same, I don't think a carrier alone is guaranteed to make the difference. For all the cost of the gas strut, I'd say it was definitely worth it. I couldn't believe how much of a difference it made. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
8th May 2019 8:55pm |
Thanks for the feedback donmacn, if it's worth fitting one then it makes sense to do it at this stage whilst everything is apart
8th May 2019 9:19pm |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 602 |
Pull the upper section of the window seal back and spray clear waxoyl in between it. My Puma door has began to rust badly from trapped water between seal and doorskin.
10th May 2019 6:25pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 898 |
I put a Puma door on my 99 MY 110 and it is great. I have a swing away carrier and a Nakatenenga upper door strut. It keeps the door open when needed in off road situations and also helps in closing the door. Also agree on putting rust inhibitor into the upper window seal. Don’t use a petroleum based product as it will swell and mess with the seal but its worth doing 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) Last edited by 4RF RDS on 13th May 2019 6:47pm. Edited 1 time in total |
11th May 2019 2:55am |
Thanks guys, I'll get some waxoyl for the job
12th May 2019 3:58pm |
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 907 |
Or, if you want to do it with a product that wasn't around in the 1960s and actually works, try here instead:
www.bilthamber.com |
12th May 2019 6:07pm |
Paul1275s Member Since: 21 Apr 2019 Location: East Sussex Posts: 80 |
I’ve just fitted a mantec wheel carrier to mine, a gas strut might assist with opening as there is quite a bit of friction within the mechanism of the mantec. I’m about to swap to a new door though as mine is proper fracked, new glass going in but it doesn’t have the wiring for the brake light so i’ll Try and run cables through the door frame. Will try and reuse the factory light though with an led bulb. 2003 Defender 110 TD5 SW
2003 Caterham 7 2006 Mini Cooper GP |
13th May 2019 8:57am |
Thanks Joe, I'll take a look at their website. Is there a particular product that you would recommend?
Paul that's similar to what mine is like although I fitted an actual LED unit rather than just LED bulb. |
15th May 2019 7:15am |
