Home > Puma (Tdci) > Clutch biting point
parktag
France 2008 Defender 130 Puma 2.4 HCPU Zermatt Silver
Clutch biting point
Hi All
I've just fitted a new HD clutch which is working as it should but the biting point is very low on the clutch pedal. Is it possible to adjust this or will it settle in? The clutch pedal itself is not in need of adjustment, only the biting point.
Thank you
Mark 130 crew cab
98 V8 Disco
Post #769880 24th Apr 2019 2:09pm
DG123
Watching with interest.
Mines the same after recent new clutch and slave cylinder; did try to adjust under clutch cover (on bulkhead) but no joy. Kind of got used to it now but driving my daughter’s car yesterday was such a difference, I need to get back on it.
Ideas anyone? 2012 110 XS SW Orkney Grey
2003 D2 Td5 Black [SOLD]
Post #769890 24th Apr 2019 4:53pm
MK
Are these clutchfix? Puma 110" SW
Post #769894 24th Apr 2019 5:14pm
DG123
No, mine was a LuK one
(Sorry Mark, for the thread hijack Whistle ) 2012 110 XS SW Orkney Grey
Post #769896 24th Apr 2019 5:24pm
leeds
Parktag, what vehicle?
Just having a chat with Ben at Clutchfix and he says
Quote:
Do you know what motor it is? It sound to be hydraulic. Pedal low is hydraulic and pedal high is worn clutch
and
Quote:
Yeah id say it was a hydraulic issue. A lot of the time people don't replace the slave cylinder when they change the clutch and that causes issues!
HTH
Brendan
Post #769907 24th Apr 2019 6:52pm
parktag
Hi All
130 TDCI 2.4. The clutch pedal is still in it's original position which is perfect so i'm reluctant to use the ajuster under the bonnet and yes i did change the slave cylinder which was surprisingly easy to bleed. Yes it is a clutchfix item. I know i'll get used to it but i don't think my other half will. 130 crew cab
98 V8 Disco
Post #769946 24th Apr 2019 11:28pm
MK
I actually have the same thing. According to clutchfix (month ago) it was a good thing as a higher biting point suggests a worn plate. Since then I bleeded it a couple of times and no air came out. Puma 110" SW
Post #769952 25th Apr 2019 12:22am
PAT303
Australia 1998 Defender 110 300 Tdi SW Alpine White
Mines the same also, I replaced everything with the new clutch and the bite point is right at the floor, I've bled it a dozen times, adjusted the peddle travel and clutch master cylinder rod to no avail, I'm thinking of fitting a longer rod to the master to fix the problem.
Post #771836 7th May 2019 4:53am
