![]() | Home > Puma (Tdci) > Clutch biting point |
DG123 Member Since: 29 Aug 2015 Location: North West Posts: 138 ![]() ![]() ![]() |
Watching with interest.
Mines the same after recent new clutch and slave cylinder; did try to adjust under clutch cover (on bulkhead) but no joy. Kind of got used to it now but driving my daughter’s car yesterday was such a difference, I need to get back on it. Ideas anyone? 2012 110 XS SW Orkney Grey 2003 D2 Td5 Black [SOLD] |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2497 ![]() ![]() ![]() |
Are these clutchfix? Puma 110" SW
No, mine was a LuK one
(Sorry Mark, for the thread hijack ![]() 2003 D2 Td5 Black [SOLD] |
Parktag, what vehicle?
Just having a chat with Ben at Clutchfix and he says
and
HTH Brendan |
parktag Member Since: 30 Sep 2008 Location: Brittany Posts: 366 ![]() ![]() ![]() |
Hi All
130 TDCI 2.4. The clutch pedal is still in it's original position which is perfect so i'm reluctant to use the ajuster under the bonnet and yes i did change the slave cylinder which was surprisingly easy to bleed. Yes it is a clutchfix item. I know i'll get used to it but i don't think my other half will. 130 crew cab 98 V8 Disco |
I actually have the same thing. According to clutchfix (month ago) it was a good thing as a higher biting point suggests a worn plate. Since then I bleeded it a couple of times and no air came out. Puma 110" SW
PAT303 Member Since: 25 Feb 2013 Location: Australia Posts: 125 ![]() ![]() ![]() |
Mines the same also, I replaced everything with the new clutch and the bite point is right at the floor, I've bled it a dozen times, adjusted the peddle travel and clutch master cylinder rod to no avail, I'm thinking of fitting a longer rod to the master to fix the problem.
